Full Version: [Solved] Kodi and MCM not working together
I've been using XBMC and MCM for 2 years and always work well and is happy with a great programs Smile
Setup is like this,
MCM search for TV serial -> Utorrent download TV show and put in folder(tilbuid)
MCM scan folder(tilbuid) and sets show in a proper folder in (TV serial)
I use my pc (win7) with XBMC to play tv watch in TV.
my HTPC (win7) crash with (XBMC) and had to re-install and installed a new XBMC (Kodi)
and now Kodi dont play new tv shows that MCM send to folder (TV serial)
Kodi play those who was previously in a folder before crash,and also if I manual copy / paste in the folder (TV serial) from folder(tilbuid)
but not as MCM brings the TV serial.
And it is the same with movies, Kodi wont play if MCM move it to folders.
I really need your expertise Smile
XBMC log if it helps Wink
http://xbmclogs.com/show.php?id=315153
Are you playing from the folder or after scanned into library? Are you saying they aren't being scanned into the library or you don't do this?
B.
Can you repost your debug log using pastebin or similar, getting a 502 error accessing your log link?
Debug Log
(2014-10-13, 20:21)k4sh1n Wrote: [ -> ]Can you repost your debug log using pastebin or similar, getting a 502 error accessing your log link?
Debug Log
http://pastebin.com/YLtcZD2g
Error 5 is access denied. Check the permissions on the file
IF MediaCenterMaster (MCM) send to tv show to folder Kodi dont play,
if I go to same folder and just copy/paste then Kodi play,
and same if I just copy tv show directly to folder then Kodi play
with same name like MCM is using.
so permissions must be right ?
It was permissions Smile
