Full Version: QUARTZ - Gotham
(2012-07-06, 07:16)adrian ballard Wrote: [ -> ]Moved
http://forum.xbmc.org/showthread.php?tid=135441
Please find my answer and reasons for moving in linked thread.
OK, for those guys and girls that want a change, fancy more fanart or find Quartz a bit dark head on to GitHub and grab yourself Quartz Reloaded.
Here's a release thread http://forum.xbmc.org/showthread.php?tid=135468 and here are some screens http://forum.xbmc.org/showthread.php?tid=135465
Have fun
Iv'e just started using quartz on my apple tv 2 after using an older version on my atv1 for a while.
Is there a wat of stopping the favorites menu popping up when pressing the menu button on the home screen?
(2012-07-08, 00:29)blazein Wrote: [ -> ]Is there a wat of stopping the favorites menu popping up when pressing the menu button on the home screen?
Yes, but not in skin. You have to edit remote key maps. Take a look at wiki, copy default mappings and delete the row that maps that button for home screen. It sounds more complicated than it is.
Got the update overnight, any chance to get the old icon view back for movies, the new one doesn't suit the width of the poster Sad
(2012-07-09, 12:13)Ilia Wrote: [ -> ]Got the update overnight, any chance to get the old icon view back for movies, the new one doesn't suit the width of the poster Sad
Screenshot, please.
Ahh interesting, under movies the "icons" view is fine, but under video playlist, the same icons view is a wider version, with only 4 per row, not the usual 7. I will get the screenshot ASAP
(2012-07-09, 12:23)Ilia Wrote: [ -> ]Ahh interesting, under movies the "icons" view is fine, but under video playlist, the same icons view is a wider version, with only 4 per row, not the usual 7. I will get the screenshot ASAP
No need, this info helps enough.
screenshot, for video playlist
http://imgur.com/VnwAM
(not sure wtf is going on posting acctual image on the forum, that link will give you an example)
Cheers
(2012-07-09, 12:31)Ilia Wrote: [ -> ]screenshot, for video playlist
Thanks, will fix.
Should be fixed on Git.
Awesome, thank you!
anychance of making tvshows custom shelf same as movies ??
i.e not square
(2012-07-10, 14:09)mikey1234 Wrote: [ -> ]anychance of making tvshows custom shelf same as movies ??
i.e not square
No, sorry it would make it too specific (someone would jump in to ask for banners) and difficult to support.
