Full Version: QUARTZ - Gotham
(2014-05-13, 12:59)queeup Wrote: [ -> ]
(2014-05-08, 20:35)bibibibi Wrote: [ -> ]I've updated to 13 and there is a problem which does not happen in the default skin.
The subtitles window is missing the file name being played so its hard to know which subtitle version to choose. This was fine in 12
I opened issue ticket. You can follow progress from here: https://github.com/pecinko/quartz/issues/36
4.5.2 is on Git
Add missing labels to subtitle download dialog
Fix opening of add ons on Android platform
Fix PVR info overlap /thanks Diego
Refresh Turkish translation /thanks Queeup
(2014-05-14, 13:02)pecinko Wrote: [ -> ]
4.5.2 is on Git
10x
When it's gonna be pused to the main xbmc repo?
(2013-11-07, 16:22)Rosell Wrote: [ -> ]Hi everybody
I'm new here and I'm french (so be gentle with my english...)
I just want to thank Pecinko to Quartz.
It just the skin I was looking for (simple, quick and customisable).
I use Quartz 4.1.4 on a my Raspberry (under RASPBMC).
Like fbacher, I have a trouble with custom image.
I explain:
I have create 4 smarts playlists for children's (2 movies and 2 TV Shows).
I state these playlists as Favorites.
I assign them images (locate in "/home/pi/img_favoris/").
When I was in Favorites, the thumbnails appear fine.
Then, I configure "Home media Shelf Customizer" to show Favoris1 and Favoris2.
On Home screen, my favorites appears instead of "new added" but there's no image.
The shortcuts run fine but for my children's, it's not very usefull.
I explore "guisettings.xml".
And I find:
<setting type="string" name="skin.quartz.ShelfMovies.6.Label">Famille</setting>
<setting type="string" name="skin.quartz.ShelfMovies.6.Icon">DefaultPlaylist.png</setting>
I fails to change "DefaultPlaylist.png".
I try "/home/pi/img_favoris/Famille-films.png".
But no success.
And when I reload the "guisettings.xml" file, it's always "DefaultPlaylist.png"
Could you help me to change this image on Home Screen please?
Hi
Like Rosell, I have a problem with favourites custom thumbnails.
- I have 4 smart playlists
- I added the 4 playlists to favourites
- I assigned a custom thumbnail to each favourites, and il appears fine in the favourites menu
https://drive.google.com/file/d/0B9mIlIa...sp=sharing
- In "Home media Shelf Customizer" movies menu, I assigned to Favorite1 = smart playlist 1 (here the thumbnail does not appear).
- On Home screen, the favourite is here, but there is no image on the shelf
Thanks for helping.
(2014-05-17, 09:54)paddy67 Wrote: [ -> ]
I explain:
And I find:
But no success.
Hi
Thanks for helping.
Seems like script.favourites bug.
Try re-posting here http://forum.xbmc.org/showthread.php?tid=114671
and be sure to provide screenshots and debug log so that script author can track that problem down.
I don't use that script. Just a fresh install of XBMC and quartz skin.
(2014-05-17, 12:55)paddy67 Wrote: [ -> ]I don't use that script. Just a fresh install of XBMC and quartz skin.
Hmmm. It is the only script used by skin. Otherwise customization would not be possible.
When I set files as favourites, il's OK the thumbnail is there, but when I set playlist as favourite, no thumbnail on the shelf.
is there a way to bring the delete file menu item out of second dun menu (on XBMC 13)?
deleting a file used to be 3 click on XBMC 12 now it's 4.
also is there a way to disbale the two 2 confirmation dialog for the deletion (1 is enough)
(2014-05-18, 08:09)bibibibi Wrote: [ -> ]is there a way to bring the delete file menu item out of second dun menu (on XBMC 13)?
All controlled by xbmc. Can't be altered in skin.
Hi pecinko,
i know you won't integrate full PleXBMC support into Quartz but maybe you could have a look at this weird BigList behavior when browsing PleXBMC content:
Also in List View there are no unwatched/partially watched indicators visible. They work in all other views.
(2014-05-19, 17:22)bigbadrabbit Wrote: [ -> ]Hi pecinko,
1st one looks like xbmc dirty regions problem. I'll check 2nd one.
BTW, Are you still using Quartz? I've thought you moved to PHT some time ago.
(2014-05-19, 18:23)pecinko Wrote: [ -> ]
You know, i'm constantly switching between those two to find the best possible experience. But spend the majority within XBMC now, because here you can have the best of both worlds.
And i always come back to Quartz. Although i'd love to have full PleXBMC support in Quartz i'm pretty happy with what you get atm. Customizing the home menu to switch directly to favorised PleXBMC sections is working pretty well and for the shelf i've also setup XBMC to scan the libraries and display the recent items on it.
Quartz is still my favorite skin of them all and although i'm testing others, i'm always coming back to this one. Wink
IF I find some time to code it, plexbmc support would come with different home page.
Does any one have the problem with Subtitles settings option? When I click it nothing happens.
Thanks,
[email protected]
another small bug. In Skin options, whatever you select for Quit option, it always get the menu popup. On my AppleTV2 is set to Quit, but it overrides that and whenever I hold the MENU buton, that is usualy QUIT, it pops up the menu.
Thanks,
[email protected]
