Full Version: QUARTZ - Gotham
pecinko Wrote:Thanks for suggestions. Currently it shows info like this:
DL TV Show info 16% (for videos)
Loading info from files 27% (for music)
Reasoning was : I can keep it in a header without a need to pop-up dialog with black background over something else, you don't see folders being scanned but rather progress. 60% of header's real estate (left part) is clean usable.
I can alter this, of course, if there's a good reason for it.
I'll give the new progress a try (once you post an update), and let you know.
tomwrob Wrote:Sorry to go over old ground - is the random item (above the menu bar) working in the latest release? If so how do I activate it? I am not on nightly builds.
Random items are bumpy ride ATM. Since I still use Dharma on my main HTPC and there are too many Dharma / pre Eden skin collisions, I decided not to include them. It may change in the future once things settle down a bit.
Quote:I also cannot make 'Addons' disappear from video menus, or 'Weather' Programs' from the XBMC menu section...
Fixed for new release.
sceaga Wrote:I'll give the new progress a try (once you post an update), and let you know.
Great.
OK, icons finished :-)
I'm quite happy with the looks considering I'm no graphical designer.
As nobody seams to be complaining about missing/broken features, I'l try to prepare new release as an repository update. Details will be available in the first post.
Remaining to consider are weather+ and random items but those would probably have to wait a bit.
Well, personally I haven't found anything to be broken, but there was one bug.. can't remember right now will post when/if I do. Fantastic job on this skin.
Slightly redesigned Weather, added Random Items and Cinema XP to VideoInfo.
A lot of work is involved with Weather+ so it's on hold for now.
Now, let me get that repo rockin' :-)
As I said Weather + is very sideline in my mind. Neat when it comes but nothing to hold up on by any means. Skin is very tight and that is without even seeing the new version!
Excited to try it out!
First post updated.
Install a repository (if you haven't already) and pull a new version from there.
*I posted a link to a ZIPs for manual install, just in case.
XBMC might report an error with random items script on nightly builds but it will should OK nevertheless. This is not a skin problem, please, see details about it in the second post. Everything should be fine in Dharma.
Have fun :-)
Thank you for update, this is fantastic, but I found some small issues (text location): with subtitles http://cl.ly/2X2Z1L0l3M2Z1E2Z0Q3C, with scanning window http://cl.ly/2t3y15410n2E09092D1n
alexdzn Wrote:Thank you for update, this is fantastic, but I found some small issues (text location): with subtitles http://cl.ly/2X2Z1L0l3M2Z1E2Z0Q3C, with scanning window http://cl.ly/2t3y15410n2E09092D1n
No problem, will fix. However, it would help to know in what window :-)
A bigger/better photo would help.
pecinko Wrote:No problem, will fix. However, it would help to know in what window :-)
1) Subtitles in OSD.
2) Scanning media library screen in home menu.
alexdzn Wrote:1) Subtitles in OSD.
1. What seams to be the problem with subtitles?
2. Scanning library overlaps to clock or?
pecinko Wrote:1. What seams to be the problem with subtitles?
1) info text overlaps
2) yes
TV shows random and recently added display wrong info. Slot 2 on the left is duplicate of info from slot 1. Again this is both for random and recently added and only happens for tv shows. Movies and music are fine.
Example:
Item 1 - Covert Affairs - S1E6 - House of the holy -> correct
Item 2 - Covert Affairs - S1E6 - Powa Maka Moana -> wrong, should say Hawaii Five-0 - S1E17
Hope this makes sens if not I can post screenshots.
Japaja Wrote:TV shows random and recently added display wrong info. Slot 2 on the left is duplicate of info from slot 1. Again this is both for random and recently added and only happens for tv shows. Movies and music are fine.
Thanks, nice catch! Fixed.
