Full Version: QUARTZ - Gotham
mikey1234 Wrote:sorry
http://pastebin.com/VaqjsqKS
i have no MyVideo.xml
You seem to be runnin pre-eden version of skin (from my repository) on latest stable XBMC - Dharma (not compatible with Quartz 2).
There's no MyVideo.xml in new Eden version.
Use newer Xbmc build from here http://mirrors.xbmc.org/nightlies/win32/
Is not required in Eden (nightly builds)
On my pc I presume I don't have latest xbmc build then downloaded of there site yesterday though
On my atv2 though I love nightly with horizontal layout Amy way to change quartz 2 to horizontal ?
Don't know ATM. I'm thinking about further steps to simplify things so there will be more changes.
I've been using Quartz Nightly 1.0.3 on my ATV2 running nightly xmbc builds and I love the skin. I recently rebuilt my ATV2 and added the repo and noticed that the nightly option is missing for quarts. I'm guessing with the release of version 2, the skin has changed to a vertical layout? Is there an option to change back to the horizontal menu?
Either way, it's a great skin and I appreciate the work that was put into it.
Not at the moment. I may add it as an alternate home layout in future releases it depends how I'll be able to solve few things.
Thanks for the reply. Is it possible to access older revisions of the skin?
vagabondking Wrote:Thanks for the reply. Is it possible to access older revisions of the skin?
if you have nightly build of xbmc just stick to confluence thats horizontal
I'm actually going to stick with Quartz 1.0.3. It's great. I love the layout and so far I have not run into any issues.
Dare i ask for an eden quartz releaseHuh
judgefred Wrote:Dare i ask for an eden quartz releaseHuh
Quartz is pre-eden/eden compatible for quite some time. Version in my repo is actualy for Eden only.
Or did you have something else in mind?
Nope. Seems its all okay Smile
Pecinko,
I've noticed an odd problem with the "Music Videos" section. When I click into the "Music Videos" it shows me the artists, and then if I click on an artist, I get an empty file list. Each one of my artist entries has at least one music video file, and I can't seem to play them that way. However, if I enable the "Recently Added" items to the main menu, I can select and play them from there.
Any ideas? This used to work fine in the Quartz V1 version.
sceaga Wrote:Pecinko,
Debugg log would probably tell some more, but my guess is it's xbmc related. Is that on beta1?
Pecinko,
This is only partially relevant, I think, so apologies in advance.
Running the latest version of PleXBMC for Eden (beta 4) I am not able to get PleXBMC integration working in the Quartz.plexbmc skin. I've tried the skin.quartz.plexbmc-0.4 skin on both a Mac mini running an October nightly of Eden and on an ATV1 running the first beta of Eden and in both cases none of my Plex libraries show up on the XBMC home screen. I have an item in my XBMC library. PleXBMC integration is checked. I've tried the Aeon Nox, Cirrus, and Confluence PleXBMC skins and all of them work fine. It's just Quartz that has issues. Which is maddening since Quartz is the skin I want to use.
I know that hippojay seems to be MIA and his version of Quartz is not current with yours but do you have any idea what could be the problem?
Any help or suggestions would be appreciated.
-berylium
