Japaja Wrote:Sounds good.
Something else I noticed is that the currently selected item moves in both TV shows and Movies. Shouldn't those be moved and remembered separately? It's not a big problem btw. just though I'd mention it too.
If you have in mind toggle between Small Cover & Small Fanart then it's planned. On other things I have no influence from a skinning point of view. Or did I miss something?
espengaasemyr Wrote:in list+info. instead of fanart. maybe press down for trailer?
In list+info you move through a list with up & down. How could I use DOWN to start a trailer in a sane way? This would be confusing for the vast majority of users.
pecinko Wrote:In list+info you move through a list with up & down. How could I use DOWN to start a trailer in a sane way? This would be confusing for the vast majority of users.
hehe my bad...maybe right or left then?
espengaasemyr Wrote:hehe my bad...maybe right or left then?
What do we lose - scrollbar or view options :-)
pecinko Wrote:Ney, I don't like them at all.
But I'll pull logo image out of skin, so you can overwrite it with your own. Win-win.
This is the best decision!
pecinko Wrote:On other things I have no influence from a skinning point of view. Or did I miss something?
It's easy to test.. go to movies scroll to movie "some name" then go to TV shows and scroll anywhere, when u return to movies the focus is no longer on movie "some name" it's reset. This doesn't happen in refocus for example so I think you do influence it from skinning point of view, but then again I could be wrong.
pecinko Wrote:What do we lose - scrollbar or view options :-)
okay then...Fanart+info. right next to info a trailer window?
Then press down for trailer? or press twice?
espengaasemyr Wrote: okay then...Fanart+info. right next to info a trailer window?
Mate this skin is about ease of use (and nice looking) - pressing twice is not the way. I will do it properly all not at all. Hopefully you'll understand. I'll really give it a thought but I'm not making promises.
Japaja Wrote:It's easy to test.. go to movies scroll to movie "some name" then go to TV shows and scroll anywhere, when u return to movies the focus is no longer on movie "some name" it's reset. This doesn't happen in refocus for example so I think you do influence it from skinning point of view, but then again I could be wrong.
I have zero influence on that. I'm using a different container, though, as I don't like seeing button sticked to bottom or top of a list.
pecinko Wrote::-)))))
Just a wish dude
I have just added trailers for 90% of my movie library.(850 Movies) and like to see a trailer before watching a movie...
If you find a way it`s great, If not no sweat.
By the way..Really smooth skin! Nice and easy interface!
You are doing a very good job
espengaasemyr Wrote:Just a wish dude
Watching a trailer before watching a movie can be done by
this addon.
