- Released 3.1.5 -
I'll be happy to hear your comments. Please report if you encounter any bugs.
Have fun
* You may encounter strange behavior on home page, that affects ATV1 running on Linux. This is ATV1 specific and does NOT happen on any other system we tested on: ATV2, OS X, Windows, Linux *
Is the skin actually quicker now? Or is it only wishful thinking?
I think it is
just a first look: maybe a bug... the custom selected Picturues/ Icons in the media shelf won`t be shown. The Shelf is all empty
Thanks for hard work, Pecinko!
Regards,
Peter
pecinko Wrote:- Released 3.1.5 -
Have fun
Is the problem where a menu item is highlighted but it shows the submenu from a different menu item? If so then this is happeing on my Windows 7 with RC2.
Cheers
nemulate Wrote:Is the problem where a menu item is highlighted but it shows the submenu from a different menu item? If so then this is happeing on my Windows 7 with RC2.
Cheers
Maybe. Any chance you could post a screenshot and describe how to reproduce error? This has never happen to me so I'm clueless where to look.
Think it may have been with me touching the touchpad on my netbook and taking the menu/submenu out of sync, wouldn't have happened on my htpc!
nemulate Wrote:Think it may have been with me touching the touchpad on my netbook and taking the menu/submenu out of sync, wouldn't have happened on my htpc!
This may happen with mouse, yes. Mouse/Touch is not recommended. It will work, but things like what you see may happen.
You would actually should hoover over Main Bar when using mouse.
Please let me know if happens with remote/keyboard.
Peter911 Wrote:Hi,
Regards,
Peter
Sorry. Fixed now (will be in next build).
This happened to me when I first upgraded. I had to disable and re-enable the skin and all was ok. Hope this helps.
I have an issue with the variables. Headings and plots etc simply show as $varGlobalHeadings or $varPlots. If anyone has come across this and can help me out it'd be appreciated.
XSDamage Wrote:This happened to me when I first upgraded. I had to disable and re-enable the skin and all was ok. Hope this helps.
You need to run XBMC Eden. VARs will go away as soon as you upgrade to newer version of XBMC.
http://mirrors.xbmc.org/releases/
Using it on my htpc with a remote and everything's looking good and working great
Any ATV1 users out there?
pecinko Wrote:You need to run XBMC Eden. VARs will go away as soon as you upgrade to newer version of XBMC.
Many thanks pecinko
Solved many issues and opened me up to new features. I hadn't realised I'd become 12 months out of date with my software, doh.
I'm a big apple fan boy, I have my iPad, iPhone and MacBook. I very nearly purchased the aTV but could not get over its limitations. Your skin gives me everything I wanted and more on my current HTPC. Thanks a million dude, your my hero!
Firstly I have to say that the skin is now so similar to the ATV interface that I have to check to see if I'm in XBMC or not. Well done.
Just a couple of observations :
1) The view in the Movie library that began with the cover art covering the left half of the screen initially before making it shrink to the top quarter and uncovering the movie synopsis doesn't seem to exist any more. Maybe I'm missing something or the animation was removed deliberately.
2) On the ATV when you select the default action for the Quit menu item it still stays displayed as being set to "menu" on the Quartz setting page, even if you have changed it to quit.
Keep up the great work
pecinko Wrote:Any ATV1 users out there?
mmhmmm ...
Just got back from out of town ... it'll be hit hard on the atv 1 tomorrow!
