Full Version: QUARTZ - Gotham
is it possible to make it work that a radio station can be added to the "favorites" of the music-tab? i can put the "radio" plugin there, but a radio station marked as "favorite" didn't start.
example picture:
is it a bug? the plugin is the radio plugin from the original xbmc repo. or is it generally not possible in eden?
What add-on are we talking about?
(2012-04-20, 22:45)pecinko Wrote: [ -> ]No problem to bring back previous behavior in next skin build.
I like the buffer bar. Even if my content is "local', for me, it's still streaming over wifi from the NAS. Sometimes my wireless gets a bit busy and skipping is less than instant. The buffer bar at least indicates what is happening.
Please keep it!
I have a problem.
The following actions do nothing:
- Clicking any episode or movie in the "home media shelf"
- Pressing C for context, or P for play, also does nothing
- Clicking, pressing C, or P, for anything in the watchlist screen
- Clicking, pressing C, or P, for anything in the recently added screen
- All the files play perfectly if I access them via the regular library
Here is a quick blurb in the log, this is when I hit play on a media shelf item
21:39:27 T:2316 DEBUG: CApplication::ExecuteXBMCAction : Translating PlayMedia($ESCINFO[Window(Home).Property(LatestEpisode.3.Path)])
21:39:27 T:2316 DEBUG: CApplication::ExecuteXBMCAction : To PlayMedia("\\Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv")
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers(\Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv)
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
21:39:27 T:2316 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
21:39:27 T:2316 NOTICE: DVDPlayer: Opening: \Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv
21:39:27 T:2316 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:39:27 T:2316 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
21:39:27 T:2316 DEBUG: DXVA - cheking samples array size using 842094158 render target
21:39:27 T:2316 DEBUG: DXVA - updated maximum samples count to 2
21:39:27 T:2316 DEBUG: DXVA - cheking samples array size using 842094169 render target
21:39:27 T:5720 DEBUG: Thread CDVDPlayer start, auto delete: 0
21:39:27 T:5720 NOTICE: Creating InputStream
21:39:27 T:5720 ERROR: CDVDPlayer::OpenInputStream - error opening [\Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv]
21:39:27 T:5720 NOTICE: CDVDPlayer::OnExit()
21:39:27 T:5720 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:39:27 T:5720 DEBUG: Thread CDVDPlayer 5720 terminating
21:39:27 T:2316 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
21:39:27 T:2316 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
21:39:27 T:2316 ERROR: XBMC.PlayMedia could not play media: \Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv
21:39:27 T:2316 NOTICE: CDVDPlayer::CloseFile()
21:39:27 T:2316 NOTICE: DVDPlayer: waiting for threads to exit
21:39:27 T:2316 NOTICE: DVDPlayer: finished waiting
21:39:28 T:2316 DEBUG: SDLKeyboard: scancode: 4b, sym: 0114, unicode: 0000, modifier: 0
21:39:28 T:2316 DEBUG: CApplication::OnKey: left (f082) pressed, action is Left
21:39:28 T:2316 DEBUG: SDLKeyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
21:39:28 T:2316 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
21:39:28 T:2316 DEBUG: CApplication::ExecuteXBMCAction : Translating PlayMedia($ESCINFO[Window(Home).Property(LatestEpisode.2.Path)])
Here's the full log
http://pastebin.com/ExgGHwpd
If i'm the only one who gets bothered by this, i have no problem to hack it myself, if you tell me how.
But thanks anyway, pecinko!
Hi
Sorry if this has been asked before, but is there anyway to turn off the badge showing the number of unwatched items in the TV Shows menu when in "Icons" view mode?
(2012-04-21, 11:01)bristol86 Wrote: [ -> ]Sorry if this has been asked before, but is there anyway to turn off the badge showing the number of unwatched items in the TV Shows menu when in "Icons" view mode?
No, unfortunately you would need to edit views manually.
(2012-04-21, 10:36)bigbadrabbit Wrote: [ -> ]
I will rework it (not sure how yet) for the next release.
In the meantime open up DialogSeekbar.xml and look for
PHP Code:
<!--<visible>Player.Caching</visible>-->
Edit it to
PHP Code:
You're done.
(2012-04-21, 06:51)vinistois Wrote: [ -> ]I have a problem.
Did you test it in Confluence?
C or P does not work on shelf or watch list screen, this is how XBMC works.
BTW, forgot to say I do not see skin problem is your log.
PHP Code:
21:39:52 T:5776   ERRORCDVDPlayer::OpenInputStream error opening [\Sayulitaserver\TV Shows\Awake\Season 01\Awake 1x08 Nightswimming.mkv
is XBMC player error. Is that path OK and accessible? Is it the same as the one you get when playing from "library"?
21:39:27 T:2316 DEBUG: CApplication::ExecuteXBMCAction : To PlayMedia(" \\ Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv")
21:39:27 T:2316 DEBUG: CPlayerCoreFactory::GetPlayers( \ Sayulitaserver\TV Shows\Parks and Recreation\Season 04\Parks and Recreation - 4x19 - Live Ammo.mkv)
Notice "\" parts. Is that OK?
(2012-04-20, 23:13)pecinko Wrote: [ -> ]What add-on are we talking about?
this one
http://wiki.xbmc.org/index.php?title=Add-on:Radio
(2012-04-21, 12:55)eastfrisian Wrote: [ -> ]
this one
Add radio to "MyStations" and add MyStations to favorites afterwards?
If i want to make custom shelf image for example music...
what size would you suggest?
(2012-04-21, 13:49)pecinko Wrote: [ -> ]
this one
yeah, this sould work. but then i have only the list with "my stations" in the favorites, not the channel, right? or will it fix the hotlink to the channel? or is it a backdoor to get the channel work?
(2012-04-21, 14:47)tikker Wrote: [ -> ]If i want to make custom shelf image for example music...
Max width=1190
Max height=202
It will be centered, so you may go 202x202 if you prefer square one or full 1190x202 if you want a banner ( http://forum.xbmc.org/showthread.php?tid=115993 )
(2012-04-21, 16:00)eastfrisian Wrote: [ -> ]yeah, this sould work. but then i have only the list with "my stations" in the favorites, not the channel, right? or will it fix the hotlink to the channel? or is it a backdoor to get the channel work?
It is a way to make a shortcut to your favorite stations. Ask add-on author is there a way to add a station to favorites.
(2012-04-09, 11:35)roidy Wrote: [ -> ]Hi, first thing, thanks for what I think is the best XBMC skin everSmile
Now I've got a small problem, the skin works fine at first boot, however if I suspend my machine and then wake it up the blue glow around the header of each menu item on the home screen is offset to the right by one position.
Reloading the skin solves it until next time I suspend the machine. I'm running XBMC 11.0 Git:14feb09 with Quartz 3.2.2
UPDATE ---------------------------------------------------------------------------------------------------------------
Quick update, I now see that there's a new version, 3.2.3, updated but the problem still exists.
I'm also having a similar problem now but I'm using quartz on a mac mini with OSX. Every time I go into setting and then back to home screen I get the misalignment between menu headers and menu items. Any way I can correct this? or is it a bug?
Same here. WAS running 3.2.5. Rolled back to 3.2.3 and it works better for the most part. Still happens, just less frequently.
