2014-10-14, 23:12
2014-10-16, 11:44
Just made about ~50 screenshots last week. Wanted to try to code a AFTV skin. I will upload them if you promise making a good looking and well usable Live TV section
2014-10-16, 11:49
(2014-10-16, 11:44)Cassiel Wrote: [ -> ]Just made about ~50 screenshots last week. Wanted to try to code a AFTV skin. I will upload them if you promise making a good looking and well usable Live TV section
hah
2014-10-16, 11:50
Here they come
Edit: Link removed cause my cell phone number was visible. Thanks to mad-max for pointing out
2014-10-16, 18:36
Many thanks.
2014-10-16, 19:43
Couldn't do some in English for me could you? Thanks.
EDIT: Actually I'll have my own next week how do you take them?
2014-10-16, 22:59
1. Download Android SDK
2. Enable Remote ADB debugging on AFTV
3. Use command line adb
If you're on OS X, you can use the following command to directly store the PNGs on your Mac instead of the AFTV itself (will save you from transferring the files to your PC via adb after taking)
./adb shell screencap -p | perl -pe 's/\x0D\x0A/\x0A/g' > screen.png
2014-10-16, 23:55
Thanks, I'm on Windows but I'll work it out.
