Hi my problem is that when i try updating the tv library and it scans the files nothing shows up after it has finished.
But with my movies there is no problem.. they show up.
I use thetvdb scraper.
/Kevin
Nobody can help you out without a proper log file.
I think the issue is your setup. It is looking for: nfs://192.168.1.111/volume1/tv-serier/Sons.Of.Anarchy.2014.S07E05.Custom.DKSubs.720p.HDTV.x264.NGSerier
XBMC is pretty strickt in the setup of your folder structure. User / TV-Serie /Seriename /Episode
I once forgot to create the folder TV-Series and that caused my scraping issues. You might want to look at that.
thx i will try see if that is the problem...
i use a sinology nas and the ds video does not have that problem but as you said xvmc is strict about the setup.
Yeah, just to add, XBMC thinks that this
Quote:DEBUG: Get: Using "UTF-8" charset for XML "http://thetvdb.com/api/GetSeries.php?seriesname=The.Vampire.Diaries.S06E02&language=en"
is a series not an episode of a series.
So, you need to make a folder called
The Vampire Diaries inside your tv-serier folder. Then make season folders inside the Vampire Diaries folder - season 1, season 2, etc. Then cut/paste your actual episodes into the correct seasons.
Note that XBMC will take the tv show name from the names of the folders inside your tv-serier folder, which is the one you should add to XBMC as the source, with the scraper set to tv-shows.
Everything should then scan correctly.
You may want to consider
filebot to sort out your naming a little better
