For the past week all I've gotten on Weather Underground is an icon of a cloud with a yellow slash through it and all temps set to 32 F.
Is the service still running for anyone?
See
here (first post should hopefully sort you
(2013-08-10, 16:20)davelr Wrote: [ -> ]For the past week all I've gotten on Weather Underground is an icon of a cloud with a yellow slash through it and all temps set to 32 F.
Same problem -- and yes I checked and the weather is enabled.
(2013-08-10, 17:36)dc361 Wrote: [ -> ]Same problem -- and yes I checked and the weather is enabled.
Which version of XBMC are you running?
(2013-08-10, 20:05)artrafael Wrote: [ -> ] (2013-08-10, 17:36)dc361 Wrote: [ -> ]Same problem -- and yes I checked and the weather is enabled.
I've tried it on 12.1 frodo on an ATV2, 12.2 git 20130502-32b1a5e (nexus7) and 13.0 alpha 6 (win7/64) with no luck.
I've done a bit more debugging --
turned off my IPV6 6in4 tunnel - no luck
checked weatherunderground web site and it brings up the weather for the city I want
After that, I tried multiple other cities in xbmc and it appears that it does work for cities in the US but not in Canada.
+1 12.2
Weather Underground had been working (with sporadic glitches) for quite a while and seemed to just stop working about 1-2 weeks ago.
Mayoman: thanks but same DC361, it is enabled and set to a correct location. Just no response and this is for a US city (Denver).
Never mind - just recycled all settings and it started working again. Since nothing was changed not sure what was going on, but now good.
(2013-08-12, 19:35)davelr Wrote: [ -> ]+1 12.2
Still no luck with Canadian sites with weatherunderground .. I can switch to Yahoo weather and it works fine..
I saw it (Weather Underground) was pulled from the repo. This is a great loss as none of the other providers gives you anything close...
pity...
(2014-10-15, 17:18)cyber7 Wrote: [ -> ]I saw it (Weather Underground) was pulled from the repo. This is a great loss as none of the other providers gives you anything close...
pity...
OpenWeatherMap has a pretty good API, I´d say it comes close. No reason to feel sad.
I just did a Amazon Fire TV XBMC (13.2) install and when i went to install the WEATHER UNDERGROUND add-on it decided to show up BROKEN. I've installed this add-on several times on Fire TV with no problems, on this very box. I'm pretty sure I can delete the add-on's DB and start over but I really don't want to do that.
Is there any way to get this working? It's a must have on my main menu.
It may be a skin issue. I use Nox and had that issue where I would select location but the window to actually do so never showed. I wound up having to switch back to Confluence, set the location then switch back to Nox. Works fine now.
how about adding a property so that folks can add their own API key?
For those interested in still using the Weather Underground add-on, here is how you can get it working again:
- Sign up for your own API key from the weather underground website, for 500 hits a day it's free.
- Inverted they key (ie. the API key - backwards)
- Use a base64 encoder online (ie.
https://www.base64encode.org/) to converted your inverted API key to base64.
- Copy the base64 encoded API key to line that includes:
WAIK = ' ' (copying the base64 encoded API key inside the single quotes)
The file that needs to be edited, is wunderground.py
I just did this and it is working perfectly again.
- Mark
