Full Version: No sound
Hi, have XBMC installed on Windows XP. Worked fine until today, Suddenly I get a red sign in the upper right corner of the screen, sort of a 'no sound' sign. Video runs fine. Any ideas?
it's on mute possibly on xbmc
or speakers are unplugged
press f8 to un-mute or the "+" sign on the keyboard to increase volume. also, if you have recently plugged in a joystick, possibly try to unplug that then use the keys above.
pressed the + sign and it worked. thanks
