2014-10-18, 19:05
Hi everyone.
I have an old XBOX with XBMC4XBOX and it can play DVD. And I have an android device (ATV1220) that can play DVD using a simple USB DVD/Blu-ray drive and XBMC 13.2.
But I see a difference:
- XBMC4XBOX detect DVD unit and use it as a DVD source so I can use my XBOX as a normal DVD player (And I see menus).
- My android device detects the USB unit and mount it on /storage/external_storage/sr0 folder, so I can see DVD files an play VIDEO_TS files, but without menu, because it's seen as a hard disk folder (So I can't use it as a normal DVD player, just inserting the disc and playing).
Can I modify anything to force XBMC to detect /storage/sr0 as a DVD drive, letting me using DVDPlayer??
I suppose I can modify any xml file or something like that, but I don't have found anything about that using Google.
Hope you can help me.
Thank you.
Thank you.
