2014-10-18, 21:44
2014-10-18, 22:02
(2014-10-18, 21:44)raze1000 Wrote: [ -> ]Sorry guys ill try again.I would just uninstall kodi and install frodo or Gotham.
Anybody have a solution to this problem as I can't install anything.
You did just ask for problems by installing kodi.
I am still making use of frodo 12.3, almost without problems.
But if I have to guess, you are making use of android...
Your previous post went to garbage, be aware what you ask on the xbmc.org forum.
2014-10-18, 22:05
(2014-10-18, 22:02)hstegeman Wrote: [ -> ](2014-10-18, 21:44)raze1000 Wrote: [ -> ]Sorry guys ill try again.I would just uninstall kodi and install frodo or Gotham.
Totally the wrong advice. Kodi is far better than Frodo/Gotham
Again we do not support any third party addons or repos that provide piracy
2014-10-18, 22:13
(2014-10-18, 22:05)Martijn Wrote: [ -> ]Helix alpha is better than stable frodo or Gotham.? ..(2014-10-18, 22:02)hstegeman Wrote: [ -> ](2014-10-18, 21:44)raze1000 Wrote: [ -> ]Sorry guys ill try again.I would just uninstall kodi and install frodo or Gotham.
In my opinion you should only make use of helix for testing.
Edit :
His previous post went to garbage, I did also respond to that.
2014-10-18, 22:16
without any doubt
2014-10-18, 22:21
(2014-10-18, 22:16)Martijn Wrote: [ -> ]without any doubtIn my opinion it's just wrong to send the first post of a user to garbage, users come to this forum without knowing the problems with third party piracy addons.
2014-10-18, 22:30
(2014-10-18, 22:21)hstegeman Wrote: [ -> ](2014-10-18, 22:16)Martijn Wrote: [ -> ]without any doubtIn my opinion it's just wrong to send the first post of a user to garbage, users come to this forum without knowing the problems with third party piracy addons.
Thank you
I wasn't aware of any of that.
I do have to admit that the kodi interface is much better, mainly for the querty keyboard.
seems a bit slicker.
Shame I can't get anything to work yet lol.
2014-10-18, 22:48
(2014-10-18, 22:30)raze1000 Wrote: [ -> ]Just uninstall kodi if you want to make use for third party addons.(2014-10-18, 22:21)hstegeman Wrote: [ -> ](2014-10-18, 22:16)Martijn Wrote: [ -> ]without any doubtIn my opinion it's just wrong to send the first post of a user to garbage, users come to this forum without knowing the problems with third party piracy addons.
Thank you
2014-10-18, 22:50
That's totally untrue. Blame the third party repos or whatever you trying to get. Just make sure you have latest Kodi nightly version installed.
Other than you will receive zero help anything piracy related
2014-10-18, 22:52
(2014-10-18, 22:50)Martijn Wrote: [ -> ]That's totally untrue.Well, which third party addons are compatible with kodi?
2014-10-18, 22:54
Go ask them. It's absolutely none of our concern if it accounts to piracy related repos. There has been zero changes since Frodo to add-ons that would break anything. So if it's broken it's their own fault for trying to do something they should not.
2014-10-18, 22:59
(2014-10-18, 22:52)hstegeman Wrote: [ -> ]I don't blame them. The third party addons work fine with frodo 12.3. I still don't need Gotham, if I would make use of android, than I would make use of Gotham, but with windows 8.1, frodo 12.3 is working fine. Windows doesn't need additional hardware support, it's was all ready available in xbmc before frodo.(2014-10-18, 22:50)Martijn Wrote: [ -> ]That's totally untrue.Well, which third party addons are compatible with kodi?
