Full Version: New Re-touched skin mod
I made modifications to the original re-touched skin by Jeez_X (http://forum.xbmc.org/showthread.php?tid=128494)
The skin looked dated and I thought i'd give it a face lift.
I call it Subtle.
Screenshots: http://imgur.com/a/IBYyc
Download: http://www.mediafire.com/download/y04gas....touch.zip
It is essential the same skin as re-touched except with a flatter design.
Changes:
Flatter, subtle design inspired by ios.
New keyboard theme.
Looks great on most resolutions.
Compatible with touch devices. No support for mouse and keyboard.
Note: The pause and primary seek buttons are transparent as they look stretched on 1280x800 displays. They are still there but transparent.
Ps:- If this is in the wrong section I do apologize, kindly refer toward the intended location for my thread. Thank you.
Credits: Jeez_X
mods are usually posted in the respective skins' forum.
i'll move yours there.
I think your addon.xml must be updated. It is currently called/id'd re-touched, so it can't be seen if re-touched is already installed. Should change id & name to subtle ...
It´s a great skin but... no live tv item Sad, the same problem than touch and re-touch
Nice concept, you should fork it from re-touched.
Any chances to put PVR working on it?
