2014-10-24, 20:56
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
2014-10-24, 20:56
(2014-10-24, 20:37)hdmkv Wrote: [ -> ](2014-10-24, 19:45)halfelite Wrote: [ -> ]I cant get used to your new name here switch back to the old. But how is the UI speed how big is your library. usually xbmc can run fluid until you get a large library going.Me? Used my real name at AVS cuz I joined there many years ago. Using hdmkv since.
So, my XBMC library consists of around 1,600 movies (2D, 3D mix) and 50 TV shows. After adding them all via VidOn's XBMC, I am noticing some slowdown (with stock Confluence) skin. I removed the few games I had installed on VidOn for testing, and only downloaded whatever version of Netflix they had on there.
So, here are some loading times:
- Pressing power on remote to VidOn main menu/UI (varies a little every time, but 34-38 secs)
- Selecting to open VidOn XBMC app to being in XBMC (5 secs)
- Pressing 'Movies' in XBMC to seeing wall view (10 secs; 5 secs or less would've been better)
- Pressing 'TV shows' in XBMC to seeing list view w/fanart and poster on right (forget what it's called) (2 secs)
Quote:i can use my Logitech harmony remoteYes, but it works no better than stock VidOn remote. Gotta stand about 5ft from box and point directly at it. I even tried an IR extender with my Harmony One, but it didn't help much. What did work better was my wireless mini-keyboard w/USB dongle connected to box. So, I will try this MCE remote, which I have.
Quote:If 3D ISO works that's all i care.Yes, now that I've figured out VidOn doesn't like certain receivers (like my Denon 1913) for whatever reason.
Can you do a good video review,if you have time?
2014-10-24, 21:10
Nice u. Figured out 3d
I hope they fix it for all avrs
Otherwise it would be a hit and miss buy
2014-10-24, 21:49
Quote:Can you do a good video review,if you have time?Thankfully, working from home today and actual work is slow, so anyway 'ask and ye shall receive'... Maybe I'll do a proper (full) video review if Wolly sends me a free unit (hint)!
2014-10-24, 21:57
Dont know if i asked but does it do 4k?
Can it boot right into xbmc?
And will it pasthrought atmos in future?
2014-10-24, 22:01
(2014-10-24, 21:49)hdmkv Wrote: [ -> ]Quote:Can you do a good video review,if you have time?Thankfully, working from home today and actual work is slow, so anyway 'ask and ye shall receive'... Maybe I'll do a proper (full) video review if Wolly sends me a free unit (hint)!
2014-10-24, 22:06
(2014-10-24, 21:57)Skank Wrote: [ -> ]Dont know if i asked but does it do 4k?No.
Not sure. Wolly?
Not sure. Wolly?
2014-10-24, 22:11
Maybe it will do 4k when its on helix
2014-10-24, 22:14
Don't know if the chip they're using is capable?
2014-10-24, 22:20
Wolly?
2014-10-24, 22:27
You one lucky son of a gun..
I wish i had this device to play with this weekend...
I think Wolly is sleeping
China Time...
(2014-10-24, 22:20)Skank Wrote: [ -> ]Wolly?
China Time...
2014-10-25, 01:19
(2014-10-22, 07:54)Willem55 Wrote: [ -> ](2014-10-22, 04:00)christoofar Wrote: [ -> ]Nice writeup. Any issues with out of synch audio? I am seeing this quite regularly on mine , especially on .mp4 files. Have had to adjust almost each one.
The worst part is really the remote - it's range is like maybe 6 feet, narrow beam. Hopefully VidOn team will continue to address things, including getting PlayStore working.
They should just lose their Media Center let Kodi do all the heavy lifting.
is your audio going through HDMI or SPdiff?
(2014-10-22, 07:38)VidOn.me-Wolly Wrote: [ -> ]We will update to Gotham very soon.
What happens if you would load kodi nightly builds?
HDMI
2014-10-25, 05:40
(2014-10-24, 21:49)hdmkv Wrote: [ -> ]Of course I can send you a VidOn Box for free.Quote:Can you do a good video review,if you have time?Thankfully, working from home today and actual work is slow, so anyway 'ask and ye shall receive'... Maybe I'll do a proper (full) video review if Wolly sends me a free unit (hint)!
Let's wait your video review.
2014-10-25, 06:00
(2014-10-24, 22:06)hdmkv Wrote: [ -> ](2014-10-24, 21:57)Skank Wrote: [ -> ]Dont know if i asked but does it do 4k?No.
Not sure. Wolly?
Not sure. Wolly?
1. No, VidOn Box doesn't support 4K.
2. We can add this feature.
3. We will consider to support it. But the existing players cannot decode it, so additional tracks are removed, and it also requires to update your amplifier.
2014-10-25, 07:56
(2014-10-25, 05:40)VidOn.me-Wolly Wrote: [ -> ](2014-10-24, 21:49)hdmkv Wrote: [ -> ]Of course I can send you a VidOn Box for free.Quote:Can you do a good video review,if you have time?Thankfully, working from home today and actual work is slow, so anyway 'ask and ye shall receive'... Maybe I'll do a proper (full) video review if Wolly sends me a free unit (hint)!
Can i get a VidOn box too(I will pay or Free,it doesn't matter)
Got so much files test.
