Full Version: pvr bug sd-channels? kodi a4 and latest nightly.
hi,
system: win7, 32 bit. pvr via mediaportal tv-server. failure: switching and watch hd-channels is fine but xbmc crashes on some sd-channels (if i switch to a sd-channel). note: some sd-channels, not all. for instance "pro 7" (germany). with xbmc 13 all is fine.
here are the last lines of the loig file.
18:41:16 T:4788 NOTICE: PVRManager - PVR::CPVRManager:TongueerformChannelSwitch - switched to channel 'RTL2'
18:41:16 T:4788 NOTICE: Creating Demuxer
18:41:16 T:4788 NOTICE: Opening stream: 0 source: 256
18:41:16 T:4788 NOTICE: Creating video codec with codec id: 2
18:41:16 T:4788 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
18:41:16 T:4788 NOTICE: Opening stream: 1 source: 256
18:41:16 T:4788 NOTICE: Finding audio codec for: 86017
18:41:16 T:4788 NOTICE: Opening stream: 3 source: 256
18:41:16 T:4788 NOTICE: Opening stream: 2 source: 256
18:41:16 T:2984 NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(720x576)
18:41:16 T:4788 NOTICE: Finding audio codec for: 86016
18:41:16 T:2984 NOTICE: DXVA::CDecoder::Close - closing decoder
18:41:16 T:2984 NOTICE: DXVA::Close - closing decoder context
18:41:16 T:2984 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:41:16 T:2984 NOTICE: fps: 0.000000, pwidth: 720, pheight: 576, dwidth: 720, dheight: 405
18:41:16 T:2984 WARNING: CXBMCRenderManager::Configure - queue size too small (2, 2, 0)
18:41:23 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: SwitchChannel(uid=46) tsreader: open a new live stream
18:41:23 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: Open Live stream for channel uid=46
18:41:24 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: Channel timeshift buffer: C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live3-0.ts.tsbuffer
18:41:24 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: Re-using existing TsReader...
18:41:24 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: TsReader: OnZap(C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live3-0.ts.tsbuffer)
18:41:24 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: Cannot access 'C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live3-0.ts.tsbuffer' directly. Assuming multiseat mode. Need to translate to UNC filename.
18:41:24 T:4788 NOTICE: AddOnLog: MediaPortal PVR Client: Translate path C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live3-0.ts.tsbuffer -> smb://NORMAN/MediaPortal TV Server/timeshiftbuffer/live3-0.ts.tsbuffer
18:41:24 T:4788 NOTICE: PVRManager - PVR::CPVRManager:TongueerformChannelSwitch - switched to channel 'ProSieben'
18:41:24 T:4788 NOTICE: Creating Demuxer
18:41:24 T:4788 NOTICE: Opening stream: 1 source: 256
18:41:24 T:4788 NOTICE: Creating video codec with codec id: 2
18:41:24 T:4788 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
18:41:24 T:4788 NOTICE: Opening stream: 3 source: 256
18:41:24 T:4788 NOTICE: Finding audio codec for: 86019
18:41:24 T:4788 NOTICE: Closing stream player 3
18:41:24 T:4788 NOTICE: Opening stream: 0 source: 256
18:41:24 T:4788 NOTICE: Creating teletext data thread
18:41:24 T:4788 ERROR: CThread::Create - fatal error creating thread- old thread id not null
18:41:24 T:4452 ERROR: PVRManager - PVR::CPVRManager:Tonguerocess - an error occured while trying to execute the last update job, trying to recover
18:41:24 T:4452 NOTICE: PVRManager - PVR::CPVRManager:Tonguerocess - no add-ons enabled anymore. restarting the pvrmanager
18:41:24 T:4788 ERROR: CreateFile 'C:\Users\Norman\AppData\Roaming\Kodi\xbmc_stacktrace-14.0-ALPHA5 Git_20141021-e235b13-20141022-184124.txt' failed with error id 32
18:41:25 T:5908 ERROR: Unhandled exception in Process : Access violation at 0x7736224d: Writing location 0x00000014
18:41:25 T:4644 ERROR: Unhandled exception in CApplication:Tonguerocess() : Access violation at 0x7736224d: Writing location 0x00000014
18:41:25 T:4644 ERROR: CreateFile 'C:\Users\Norman\AppData\Roaming\Kodi\xbmc_stacktrace-14.0-ALPHA5 Git_20141021-e235b13-20141022-184125.txt' failed with error id 32
18:41:25 T:5908 ERROR: CreateFile 'C:\Users\Norman\AppData\Roaming\Kodi\xbmc_crashlog-14.0-ALPHA5 Git_20141021-e235b13-20141022-184125.dmp' failed with error id 32
same problem with latest nightly. here is a full debug log:
http://pastebin.com/z7fGQN5T
it seems to be a problem with the included mediaportal pvr addon: http://forum.kodi.tv/showthread.php?tid=208130
same problem with beta2. it seems it has nothing to do with mediaportal pvr addon, its a bug in kodi + teletext (see link above).
I can confirm it
can you provide a recording which includes teletext to reproduce the issue?
(2014-11-12, 15:59)FernetMenta Wrote: [ -> ]this should fix it: https://github.com/xbmc/xbmc/pull/5702
Yes, it does. Many thanks!
