2014-11-04, 11:23
(2014-11-04, 04:40)Raptor69 Wrote: [ -> ]Memphiz, any idea what I'm doing wrong ? ?
This is totally offtopic to this thread - please open a new one so that someone can answer your question.
(2014-11-04, 09:50)Kismukk Wrote: [ -> ]Same problem here. iPad 3, xbmc version: 13.2-2.
14 FPS during a 720p mkv playback
Uploaded a debug log.
http://xbmclogs.com/show.php?id=340437
Thanks Memphiz
(2014-11-04, 13:44)Memphiz Wrote: [ -> ]Please try this build on the ipad3:On my Ipad3 this build fixed that problem.
http://mirrors.xbmc.org/test-builds/darw...s8-ios.deb
(2014-11-04, 18:00)pogo1975 Wrote: [ -> ](2014-11-04, 13:44)Memphiz Wrote: [ -> ]Please try this build on the ipad3:On my Ipad3 this build fixed that problem.
(2014-11-04, 21:09)Memphiz Wrote: [ -> ]can you ipad3 users please verify if this version still fixes the hd stutter?
(2014-11-04, 22:21)Memphiz Wrote: [ -> ]Could you also try the latest nightly build? (please backup /var/mobile/Library/Preferences/XBMC before because it will be moved during installation). I really wonder if the issue is there too. I only have an iphone4s running ios6 and it doesn't stutter - the ipad3 should be more powerfull. While i don't have a problem to do a gotham 13.2-3 release with that fix/workaround i hesitate a bit in doing the same for helix. Hence i need to be sure that it is needed there. (the workaround clamps the rendered resolution which is something i wanted to get rid of for all retina devices...)
(2014-11-04, 23:15)Kismukk Wrote: [ -> ]Unfortunately after the succesfull kodi nighly install, there is no icon on the "desktop" of the iPad to start the app. I tried uninstall kodi and install back the last version of xbmc, but after a successfull install still there is no app icon. Of course I tried some reboot on the iPad. Do you have any idea how can I recreate the app icon on the iPad "desktop"?
(2014-11-05, 03:04)Ned Scott Wrote: [ -> ](2014-11-04, 23:15)Kismukk Wrote: [ -> ]Unfortunately after the succesfull kodi nighly install, there is no icon on the "desktop" of the iPad to start the app. I tried uninstall kodi and install back the last version of xbmc, but after a successfull install still there is no app icon. Of course I tried some reboot on the iPad. Do you have any idea how can I recreate the app icon on the iPad "desktop"?
Try installing another app from Cydia to make it "unstuck". Sometimes it won't show up until you do that even if you reboot and respring.
