Full Version: NBC Sports Live Extra
Can anyone recommend a decent VPN to use that's reliable and cheap-ish. I used to use hotspot shield but suddenly it dosnt work with this addon
(2015-08-05, 00:56)Meerkat118 Wrote: [ -> ]Can anyone recommend a decent VPN to use that's reliable and cheap-ish. I used to use hotspot shield but suddenly it dosnt work with this addon
PIA VPN is what I use and can not fault it. Roughly 25 GBP converted from 40 USD on the 12 month subscription. You can have 5 simultaneous connections too.
(2015-08-05, 01:17)MJPorter89 Wrote: [ -> ]
Any issues using it on OpenElec/Raspberry Pi's or Windows etc?
(2015-08-05, 01:25)Zorb Wrote: [ -> ]
None at all. I have kodi on a Mac, a windows machine, a raspberry pi 2, and an android phone. All happily running PIA simultaneously.
My raspberry pi is running open elec and there is a PIA add on that I use on this.
(2015-08-05, 01:28)MJPorter89 Wrote: [ -> ]
(2015-08-05, 01:17)MJPorter89 Wrote: [ -> ]PIA VPN is what I use and can not fault it. Roughly 25 GBP converted from 40 USD on the 12 month subscription. You can have 5 simultaneous connections too.
Do you need to use any other service like Unotelly DNS or VPNicity etc to get this addon to work?
(2015-08-05, 01:57)Zorb Wrote: [ -> ]
(2015-08-05, 01:25)Zorb Wrote: [ -> ]Any issues using it on OpenElec/Raspberry Pi's or Windows etc?
No i have a Comcast Xfinity log in, and then just use PIA to VPN.
my login dont work on this but works fine on app
i using comcast btw
thanks
ps using smart dns
(2015-08-05, 03:32)mohanned85 Wrote: [ -> ]my login dont work on this but works fine on app
i using comcast btw
thanks
ps using smart dns
You need to use VPN as smart DNS usually doesn't work.
(2015-08-05, 02:02)MJPorter89 Wrote: [ -> ]
(2015-08-05, 01:28)MJPorter89 Wrote: [ -> ]None at all. I have kodi on a Mac, a windows machine, a raspberry pi 2, and an android phone. All happily running PIA simultaneously.
Great. I'll give the 7 day access a trial and if all works, I can cancel my other vpns and dns things.
(2015-08-05, 09:27)Zorb Wrote: [ -> ]
(2015-08-05, 01:57)Zorb Wrote: [ -> ]Do you need to use any other service like Unotelly DNS or VPNicity etc to get this addon to work?
Let us know how you get on!
i use cyberghost £9.99 for the year works for me judt have to clear data saved a couple of times.laptop windows 8.1
I'm in the UK, got a SmartDNS VPN placing me in W USA, using the latest version with a Direct TV login and 8 times out of 10 I get 'Failed to authorize'.
I keep deleting the program data as suggested earlier but has anyone worked out a permanent fix for this?
(2015-08-05, 14:34)simonv74 Wrote: [ -> ]I'm in the UK, got a SmartDNS VPN placing me in W USA, using the latest version with a Direct TV login and 8 times out of 10 I get 'Failed to authorize'.
am in the uk cyberghost 9.99 a year works for me but am on a fast connection
think most people have to delete saved data just one of them things
(2015-08-05, 15:16)jeff woad Wrote: [ -> ]am in the uk cyberghost 9.99 a year works for me but am on a fast connection
I get ~12mb download when connected to VPN so actual playback is no issue once I get past the 'Failed to authorize' part - just wish there was a fix!
I suppose it's heartening to know I'm not the only one...
im having the same trouble as a lot on here.I have Comcast account, PIA set to Florida.It was working fine yesterday, but the username and password keeps coming up.
