Full Version: NBC Sports Live Extra
i clear data restart kodi or vpn takes a couple of tries but always get it to work
Latest beta has been submitted to the official kodi repo. It should be showing up in the next day or two.
(2015-08-05, 16:50)donjuan400 Wrote: [ -> ]im having the same trouble as a lot on here.I have Comcast account, PIA set to Florida.It was working fine yesterday, but the username and password keeps coming up.
Have you tried clearing the saved data?
Also, does it work fine using the Comcast website?
Yes i have cleared the data loads of times but still the same," password failed" I havent tried the Comcast site but the sub is working on my android phone no problem.
I can confirm that PIA works for me by setting the region to East in the NBC plugin and choosing New York in the Private Internet Access app. (this is on an android box but should work for PC aswell) Also I sometimes need to clear saved data.
All events in blue play both live and replays. Big Grin
Do the people who have got it working with Cyberghost Premium use the android app or are you using a PC?
Hello guys,
Nearly the first weekend of live EPL games, would like to wish you all good luck with your different clubs and once again a big thank you to Mr. Phobia that we all can watch live in HD video quality !
(2015-08-06, 11:06)ben.bell1987 Wrote: [ -> ]I can confirm that PIA works for me by setting the region to East in the NBC plugin and choosing New York in the Private Internet Access app. (this is on an android box but should work for PC aswell) Also I sometimes need to clear saved data.
Tried it that way but no luck, still asking for user and password which are in and active in android phone.(not at the same time though)
hi will you be adding uverse to the login feature ?
Hi, installed PIA on Windows, Pi2 and Android phone.
Each one gets live no problems, spotlight is fine as is showcase, but for some reason the Full Replays just wont run.
As long as all the premier league and nascar stays on Live & Upcoming I think i'll be fine to cancel my other vpns and dns providers! I'll fully test on saturday for the footy!
(2015-08-05, 03:32)mohanned85 Wrote: [ -> ]my login dont work on this but works fine on app
i using comcast btw
thanks
ps using smart dns
I ditched SmartDNS, just not up to the job.
I went back to Switch VPN and use the Chicago server. Now I can log in, in one or two tries and no buffering/stopping.
Just hope it holds out for tomorrow for the big kick off...
(2015-08-07, 00:48)Zorb Wrote: [ -> ]Hi, installed PIA on Windows, Pi2 and Android phone.
Have you got the very latest version of NBC SLE (2015.7.31) installed? Also, which US connection are you using, I've found Florida has been 100% reliable so far.
Am using 2015.7.31 but choosing the east vpn. I'll try the florida one. Currently using the east vpn at the moment.
(2015-08-06, 17:49)harristimnz Wrote: [ -> ]hi will you be adding uverse to the login feature ?
Sure, if someone with a uverse account wishes to share their account details with me.
hI do you know of a way to make the nbc work within kodi using smartdns or another dns program
