Any chance of adding AT&T Uverse to the service providers?
(2015-08-08, 14:10)eracknaphobia Wrote: [ -> ]Patched the issue. Download update here:
https://github.com/eracknaphobia/plugin....master.zip
Legend!
This patch gets it working for me on XBMC 13.1 for whatever that's worth.
Playback keeps dropping, but launches again fine every time. Maybe that's a load thing on the NBC side, I don't know.
(2015-08-08, 14:18)stammie Wrote: [ -> ]All working for me too without installing eracknaphobia's latest patch.
What a shame Tottenham just scored an own goal
Installed the latest patch at half time and working too, Minix/Android/Kodi/Smart DNS/VPN
(2015-08-08, 13:59)dashtekahe Wrote: [ -> ]it is not working now for Manu match under any circumstances on kodi with any VPN. It was working earlier with full replays and no problem but no for the match not working. I think NBCs done something.
This happened to me, was fine before the update but then got the script error. It took me ages to realise that the cable provider in the settings has been changed to 'Cable One'. Changed it back to Comcast (Xfinity) and it works fine now. Don't know if this is the same for you but worth having a look.
Thanks mate, I corrected that part but still no luck with even the patched version. I am able to pass the first step and get to the single link but then it says "one or more items failed to play..."
........updated
Ok it seems that the problem is my VPN as I tried a few cities and changed them and tried a few times and it worked finally.
I'm working fine watching the Bournemouth game on kodi using pia VPN and I'm on Comcast too
Still not working for me sadly - i'm on win 7/kodi 15.0/unotelly and have a xfinity login.
Upgraded to the latest patched version but still getting the invalid user/pass error. Can log in to the website fine, just not kodi.
Any ideas?
(2015-08-08, 16:43)johhhnnn Wrote: [ -> ]Still not working for me sadly - i'm on win 7/kodi 15.0/unotelly and have a xfinity login.
Any ideas?
I would hazard a guess this is because you're using a DNS service, via a VPN this is working absolutely fine.
Thank you eraknaphobia for all your hard work during the summer, NBC was ok via their app but is so much better via Kodi
FYI
VPNicity are now offering 1 Month Free if anyone wants to try that VPN solution out.
I need to clear saved data when switching between matches on a windows PC running PIA.
Also, not sure if the latest patch gives a new version on the plugin but I uninstalled the old 15.7.31 and put the new one on but the version seems the same.
(2015-08-08, 16:54)stammie Wrote: [ -> ] (2015-08-08, 16:43)johhhnnn Wrote: [ -> ]Still not working for me sadly - i'm on win 7/kodi 15.0/unotelly and have a xfinity login.
Any ideas?
I'm pretty sure the dns service is working fine as I can play the free content no problem. Without the dns this wouldn't play. It'd definitely as username/password issue
Hi, I'm running KODI v15 and I've just updated the NBC Live Extra Add-On to the newly patched version and it keeps asking me to check my username and password. I have confirmed several times that my login details are correct and they work fine on the NBC Live Extra website.
I am running a US VPN and have tried multiple different cities as another user suggested with no luck. Any ideas what I might be doing wrong?
I should also add I'm using a Comcast (Xfinity) username and password.
I've got AFTV. when I'm using the Kodi app and it keeps asking me to check my username and password.
When I switch to the official app sideloaded into AFTV it works fine.
(2015-08-07, 14:35)eracknaphobia Wrote: [ -> ] (2015-08-06, 17:49)harristimnz Wrote: [ -> ]hi will you be adding uverse to the login feature ?
Sure, if someone with a uverse account wishes to share their account details with me.
(2015-08-08, 17:12)DixieDean Wrote: [ -> ]FYI
I tried them and in general it was fine but couldn't get it to work on openelec properly.
Same thing happening with me, the Kodi (or OSMC) addon it asking to verify username and password, I've used VPNicity and UnoTelly VPN with the same result, the Windows app works absolutely fine
