(2015-08-08, 21:45)DanMorris24 Wrote: [ -> ]Help please. I have vpn installed using Hola. I have also installed the add on. But I'm still not getting any live channels or replays. Either getting a message of playback failed. Or log in credentials needed....
I am in the UK and using an android mxq box
Are you using a VPN and have you put your login details in the add on??
(2015-08-08, 07:44)snick Wrote: [ -> ]I'm in the US and have a login which I just tested on NBC sports website, so its good.
I get "Failed to Authorize" on kodi using it.
Here's the associated log:
https://gist.github.com/nickwales/835534270ce44594de1e
I've just tried the latest master release.
Works now, I'm assuming todays patch fixed it.
I keep getting I get "Failed to Authorize" on kodi 15 windows 10 . updated to the master version also have login and privateinternetaccess vpn any ideas guys .
(2015-08-09, 00:54)bobo06 Wrote: [ -> ]I keep getting I get "Failed to Authorize" on kodi 15 windows 10 . updated to the master version also have login and privateinternetaccess vpn any ideas guys .
clear saved data sometimes takes a couple of goes
Hi im brand new here so if im in the wrong place I wud like to apologise but i was wondering if someone cud give me some info on how to get login details for the nbcsn extra addon .... im a total noob but willing to listen n learn and all I want to do is be able to watch my beloved lpool fc ....
Hello, please be advised I have an active VPN with PIA, however the issue I have is the login details I hold are for ATT Uverse but you not appear to have that provider listed as a selection.
On this note is it possible this may be added.
Thanks,
(2015-08-09, 06:18)ste pilkington Wrote: [ -> ]Hi im brand new here so if im in the wrong place I wud like to apologise but i was wondering if someone cud give me some info on how to get login details for the nbcsn extra addon .... im a total noob but willing to listen n learn and all I want to do is be able to watch my beloved lpool fc ....
The first post is the most important post to read.
Still same problem for me with openelec, free streams play fine but my Xfinity login and username is not recognised (works fine on the website, but not here).
Do the free streams working mean my VPN is doing its job and the problem is elsewhere?
Would love to get this work as the streams are excellent quality.
Cleared it loads of times it's still spitting out same error. I've tried a few versions updated kodi also .
(2015-08-09, 02:05)jeff woad Wrote: [ -> ] (2015-08-09, 00:54)bobo06 Wrote: [ -> ]I keep getting I get "Failed to Authorize" on kodi 15 windows 10 . updated to the master version also have login and privateinternetaccess vpn any ideas guys .
Just got PIA and I'm getting the same "Failed to Authorize", im connecting to tampa, florida... How do i clear saved data? (sorry for being a retard)
Iv got the same problem it worked fine yesterday but today it says login failed.
Iv also got an xfinity login and I'm using pia vpn.
It's in the next tab to the login details.
i've press than a lot of times and nothing happens, should this make the addon forget my username and password because it doesnt
Just noticed the Arsenal game is active (blue). It loads the secondary link but it fails to play. I know the coverage wouldn't have started yet but might have expected the KBC logo with this programme will start shortly. All replays are working etc.
Ok iv got it working again now I used the patch and cleared the data and now its all working fine.
Thanks from the U.K guys.
