(2015-08-15, 16:15)stammie Wrote: [ -> ]Same for me, it went off at 87 minutes on the Saints-Everton game,
I've switched to the Windows app for now which is working well but is highlighting to me the difference between Kodi's superior picture processing and the apps ok but nowhere near as good picture quality even at its full bitrate.
EDIT:
I guess its a problem with the IOS streams, going by a post on another forum Apple device streams aren't working correctly but Android ones are and I have the Windows one working perfectly.
There working fine on the official app using my iPad. I think the addon uses the iphone streams. I'f I remember correctly they changed them before so we prob just have to sit tight for a fix. Maybe that they change the, every weekend just to give us the run around!
(2015-08-15, 16:29)Olliepop Wrote: [ -> ] (2015-08-15, 16:15)stammie Wrote: [ -> ]Same for me, it went off at 87 minutes on the Saints-Everton game,
EDIT:
I tried on my iphone and appletv both where un-watchable sadly its still the case
(2015-08-15, 16:32)j2220 Wrote: [ -> ] (2015-08-15, 16:29)Olliepop Wrote: [ -> ] (2015-08-15, 16:15)stammie Wrote: [ -> ]Same for me, it went off at 87 minutes on the Saints-Everton game,
EDIT:
Just tried on my iPhone and that's fine also.
Working for me on android box with free vpn never buffered once
(2015-08-15, 16:36)Olliepop Wrote: [ -> ] (2015-08-15, 16:32)j2220 Wrote: [ -> ] (2015-08-15, 16:29)Olliepop Wrote: [ -> ]There working fine on the official app using my iPad. I think the addon uses the iphone streams. I'f I remember correctly they changed them before so we prob just have to sit tight for a fix. Maybe that they change the, every weekend just to give us the run around!
Where are you ? are you using a dns service or a vpn dont name then
Watching sunderland game from UK with free vpn also dns
I've got both VPN and DNS also.. Neither work
Broke on kodi, I either get failed to authorize or it fails to play message.
Got failed to authorise just went out then back in
I'm not getting failed to authorise at all. Just keep getting failed to play. Please see logs.
(2015-08-15, 16:49)regy27 Wrote: [ -> ]Got failed to authorise just went out then back in
You mean it's no longer working? Or that's what you did to get it working?
If I go out then try to go back in a get failed to outhrise but let's me in after few trys
The replays work fine so it's prob a case of them changing the links for the iPhone.. I maybe wrong thought!
Failed to play error here
