My windows stream is going a bit mental as well now watching the newcastle game.
Just came up at 53 mins in second half "coverage will resume shortly"
(2015-08-15, 17:15)GTunney Wrote: [ -> ]My windows stream is going a bit mental as well now watching the newcastle game.
Mine also. Maybe NBC (shock!) is just having some issues in general on their end.
I don't think it's the add-on I think it is the NBC website because all the streams have gone off on there as well. Watching it Spurs vs Stoke on another add-on now that is working fine.
From the NBC Sports Twitter:
"We are currently aware of issues with Live Extra and we are working diligently to fix the issue. We apologize for the inconvenience."
Looks that way Everton game worked fine although didn't work with two VPN providers but did with dns
Sunderland match worked fine until second half then couldn't get back on
I got kicked out in the middle of the first half of the Spurs match
After a bit of help. Got vpn running valid comcast login but still getting failed to authorise. Can anyone help.
Hi had the same problems only 1 game work for about 5 min and the rest did not, also was wondering why is the streams only 720p last season they were 1080p ?
(2015-08-15, 20:15)Wishmaster Wrote: [ -> ]Hi had the same problems only 1 game work for about 5 min and the rest did not, also was wondering why is the streams only 720p last season they were 1080p ?
I think they were 720 last year not 1080? The golf chan is 1080, hopefully nbc will fix the issues and it's not the plugin.
The blue links appear to be working again now so I'm assuming it was the fault at their end.
Got that too, it was going so well!
No live links working for me except the golf channel
Its working now on a live link but cuts off after two minutes.
(2015-08-16, 07:35)redbellied Wrote: [ -> ]Its working now on a live link but cuts off after two minutes.
I have the same problem too, all works ok but stops after 2 mins.
