Full Version: NBC Sports Live Extra
Using PIA I get the following error on a Raspberry Pi
08:36:24 T:2775577664 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: timestamp out of range for platform time_t
File "/home/pi/.kodi/addons/plugin.video.nbcsnliveextra-beta/nbcsn.py", line 429, in <module>
SIGN_STREAM(url, name, icon_image)
File "/home/pi/.kodi/addons/plugin.video.nbcsnliveextra-beta/nbcsn.py", line 276, in SIGN_STREAM
saml_response, relay_state = provider.LOGIN(var_1, var_2, var_3)
File "/home/pi/.kodi/addons/plugin.video.nbcsnliveextra-beta/resources/providers/cable_one.py", line 19, in LOGIN
login_url = self.FIRST_BOOKEND(first_bookend_url_2)
File "/home/pi/.kodi/addons/plugin.video.nbcsnliveextra-beta/resources/providers/cable_one.py", line 114, in FIRST_BOOKEND
cj.save(os.path.join(ADDON_PATH_PROFILE, 'cookies.lwp'),ignore_discard=True);
File "/usr/lib/python2.7/_LWPCookieJar.py", line 89, in save
f.write(self.as_lwp_str(ignore_discard, ignore_expires))
File "/usr/lib/python2.7/_LWPCookieJar.py", line 75, in as_lwp_str
r.append("Set-Cookie3: %s" % lwp_cookie_str(cookie))
File "/usr/lib/python2.7/_LWPCookieJar.py", line 35, in lwp_cookie_str
time2isoz(float(cookie.expires))))
File "/usr/lib/python2.7/cookielib.py", line 99, in time2isoz
year, mon, mday, hour, min, sec = time.gmtime(t)[:6]
ValueError: timestamp out of range for platform time_t
08:36:24 T:3037913088 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.nbcsnliveextra/?url=http%3A%2F%2Fnbcstreameast.nbcsports.com%2Fnbc07%2Fed7ae353-6643-4c1a-bbf7-974f6d062efa%2Fnbc-sports-live-extra0926021233.ism%2FQualityLevels%283450000%29%2FManifest%28video%2Cformat%3Dm3u8-aapl-v3%2Caudiotrack%3Daudio_en_0%29&mode=5]
Any ideas what can be done to fix this?
I'm getting authorization issues with a valid DTV account. The logs from the request are here:
https://gist.github.com/anonymous/4f2521a5403d96d8ee21
would it be possible to add a proxy config to the addon.
reason i ask is i can fire up a VPS but can only use IPV6 address so not able to use the vps as a DNS and i only want to proxy this app nothing else.
i can set a subdomain to the VPS.
this would ensure no captcha and would mean only 1 IP ever accessing the account
Add-on works nearly flawlessly for me, outstanding work. Although, The Dan Patrick Show "crashes" after ~5 minutes, returns to the stream selection screen without error. Debug log is below.
http://xbmclogs.com/pxzrvq0cl
(2015-09-30, 17:17)uschxc Wrote: [ -> ]Add-on works nearly flawlessly for me, outstanding work. Although, The Dan Patrick Show "crashes" after ~5 minutes, returns to the stream selection screen without error. Debug log is below.
im having the same issue with other shows - stream closes after 3-5 minutes this is for NBCSN and not live streams
This would be a live stream for me, strangely enough its working pretty well today. Fingers crossed
Hi guys, any idea what goin on in the following log? nbc was working earlier, now when I click live and upcoming I get an error. The only thing changed since it last worked is I installed a new skin, aeon mq5 but I have since reverted back to confluence for testing and it still doesnt work. log as follows:
Thanks for any help.
22:18:46 T:140473722930944 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: No JSON object could be decoded
File "/storage/.kodi/addons/plugin.video.nbcsnliveextra/nbcsn.py", line 442, in <module>
LIVE_AND_UPCOMING()
File "/storage/.kodi/addons/plugin.video.nbcsnliveextra/nbcsn.py", line 35, in LIVE_AND_UPCOMING
SCRAPE_VIDEOS(ROOT_URL+'mcms/prod/nbc-live-ios.json')
File "/storage/.kodi/addons/plugin.video.nbcsnliveextra/nbcsn.py", line 73, in SCRAPE_VIDEOS
json_source = json.load(response)
File "/home/stephan/projects/openelec-6.0/build.OpenELEC-Generic.x86_64-5.95.5/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 278, in load
File "/home/stephan/projects/openelec-6.0/build.OpenELEC-Generic.x86_64-5.95.5/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads
File "/home/stephan/projects/openelec-6.0/build.OpenELEC-Generic.x86_64-5.95.5/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode
File "/home/stephan/projects/openelec-6.0/build.OpenELEC-Generic.x86_64-5.95.5/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
ValueError: No JSON object could be decoded
22:18:46 T:140475078522752 ERROR: GetDirectory - Error getting plugin://plugin.video.nbcsnliveextra/?icon_image=%2fstorage%2f.kodi%2faddons%2fplugin.video.nbcsnliveextra%2ficon.png&mode=1&name=Live%20%26%20Upcoming&scrape_type=None&url=%2flive
22:18:46 T:140475078522752 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra/?icon_image=%2fstorage%2f.kodi%2faddons%2fplugin.video.nbcsnliveextra%2ficon.png&mode=1&name=Live%20%26%20Upcoming&scrape_type=None&url=%2flive) failed
Would be great if you could code Hotwire Communications. I can provide my login details, is it possible for you to message me as I am currently not that active and very new to the community
(2015-10-05, 02:30)platty3000 Wrote: [ -> ]Would be great if you could code Hotwire Communications. I can provide my login details, is it possible for you to message me as I am currently not that active and very new to the community
See the OP
Am I allowed to ask how to get this working from the UK? My cable provider is Sky TV. I would be more than happy to pay for this service. Any help would be greatly appreciated.
From my experience you'll have problems with sky
(2015-10-05, 14:51)whosagooner Wrote: [ -> ]Am I allowed to ask how to get this working from the UK? My cable provider is Sky TV. I would be more than happy to pay for this service. Any help would be greatly appreciated.
To get it to work you need a USA cable subscription which you can only have as a USA citizen, you need a friend or family in the USA, a good VPN or DNS is needed too as NBCSLE is geo blocked !
Anyone else getting the 'failed to authorize' error today when trying to play a video? No issue with the login on the site, but won't work on Kodi for whatever reason.
(2015-10-09, 02:52)number1fan Wrote: [ -> ]Anyone else getting the 'failed to authorize' error today when trying to play a video? No issue with the login on the site, but won't work on Kodi for whatever reason.
Same as me, tried with many credentials, work on website, windows 8 app. but failed to authorize on android box or openlec Kodi. Not for all, about 70% failed.
Working fine here.
