Full Version: NBC Sports Live Extra
Hi guys
I am in the UK and have been reading about 'VPN Unlimited' that are doing a 3 year deal for about £12.00. I was wondering if anyone else has used this provider and if so is it any good?
Many thanks
(2015-10-26, 23:02)redbellied Wrote: [ -> ]
(2015-10-26, 21:48)ri0t Wrote: [ -> ]
(2015-10-26, 16:44)huizingajm Wrote: [ -> ]Are you selecting DirectTV as the provider under the settings when you put in your username and password?
Yes I am.
Highlight the stream, go into the context menu and try playing from there.
Same result, slightly different message "Failed to Authorize" where the original message was "Verify username and password"
I know the credentials are correct as I am using them on other devices that have a native NBC Sports LE app (iOS)
Try clearing the saved data before you try again.
(2015-10-27, 14:25)ri0t Wrote: [ -> ]
(2015-10-26, 21:48)ri0t Wrote: [ -> ]Yes I am.
same issue here.
(2015-10-27, 14:26)redbellied Wrote: [ -> ]Try clearing the saved data before you try again.
did that as well to no avail Sad
I'm having issues with this addon somewhat out of nowhere. After recently downloading this addon, I have been able to watch the golf channel in great quality with little to no issues streaming/buffering. However, yesterday when I tried to watch, I clicked on watch golf channel and a waiting message popped up for about a second then disappeared and I was back at the screen to select which stream to watch without any sort of error message or anything to explain why it wouldn't play. Anyone else having similar troubles? Any help is appreciated.
I am not running a VPN. I do not have my Verizon login information entered, however I did a few days ago and then realized that I didn't have access to the golf channel because I don't have that as part of my TV plan so I deleted the login info. Is there some way that once the addon realizes you don't have access, it will prevent it even if you remove your info?
Guys... Quick question for those more TECH SAVVY than me...
If i had a login for nbcsn... is it possible to then use a scraper to pull all the 3pm games etc from within the website?
I dont want to know how to do it etc.. thats not what im asking...
Only can it be done?
As i want to call someone out on something.
Any info would be great guys
(2015-10-28, 11:30)Sauci Wrote: [ -> ]I'm having issues with this addon somewhat out of nowhere. After recently downloading this addon, I have been able to watch the golf channel in great quality with little to no issues streaming/buffering. However, yesterday when I tried to watch, I clicked on watch golf channel and a waiting message popped up for about a second then disappeared and I was back at the screen to select which stream to watch without any sort of error message or anything to explain why it wouldn't play. Anyone else having similar troubles? Any help is appreciated.
Highlight the golf channel, go into context menu and play stream from there option.
(2015-10-17, 15:20)paxrax Wrote: [ -> ]if youre using chrome or android, try the zenmate plugin/app , works a treat!
I have used this 3 or 4 times and it works very well even the free version! No buffering, just had to click the 'clear saved data' button before playing the odd time.
I recommend Zenmate Android App, even works on android phones with the Live Extra app.
(2015-10-28, 15:39)redbellied Wrote: [ -> ]
Tried that. context menu drops and I'm just sitting there with the list of streams. No error message nothing. Just no playback.
I am running a android box with SPMC in the UK, i have downloaded the NBC sports add-on and use a vpn. When i click on the premier league games its says a account/ sign in required, where do you sign in with your account details(not that i have acquired one yet, still looking to see where i can get one)
Any help greatly appreciated.
@Oompa Loompa read the first post of this thread please.
(2015-10-29, 12:04)Sauci Wrote: [ -> ]
Try uninstalling the addon and closing down Kodi, then go to your userdata folder and and delete the plugin.video.nbcsnliveextra folder found within the addon_data folder in there.
After that fire up Kodi and reinstall the addon, hope this helps
@bry I have and if you are refering to not asking for login details, I haven't I have asked how to enter the details.
So as I said any help would greatly appreciated.
(2015-10-29, 19:29)Oompa Loompa Wrote: [ -> ]@bry I have and if you are refering to not asking for login details, I haven't I have asked how to enter the details.
get the kodi app and right click on it
