Full Version: NBC Sports Live Extra
(2015-10-29, 19:43)dexg1 Wrote: [ -> ]
(2015-10-29, 19:29)Oompa Loompa Wrote: [ -> ]@bry I have and if you are refering to not asking for login details, I haven't I have asked how to enter the details.
So as I said any help would greatly appreciated.
get the kodi app and right click on it
i find dns settings are better
(2015-10-29, 17:39)stammie Wrote: [ -> ]
(2015-10-29, 12:04)Sauci Wrote: [ -> ]
(2015-10-28, 15:39)redbellied Wrote: [ -> ]Highlight the golf channel, go into context menu and play stream from there option.
Tried that. context menu drops and I'm just sitting there with the list of streams. No error message nothing. Just no playback.
Try uninstalling the addon and closing down Kodi, then go to your userdata folder and and delete the plugin.video.nbcsnliveextra folder found within the addon_data folder in there.
After that fire up Kodi and reinstall the addon, hope this helps
When entering the userdata folder, the only item is a RssFeeds xml document. No addon_data folder.
@dexg1 thank you for all your help
is this happening to anyone else im running windows 8.1 and an mx3 android box . first thing i cant get golf channel to work and have to turn vpn off to get to things then i have to turn vpn back on once ive chosen something to watch. this is happening to both the windows and andriod i have a comcast account this has onlt started to happen this week . other than that the app has been perfect for the last year or so . any feedback gratefull. now gonna try my sony android tv and will report back .....
well ive just tried my sony android tv and the same problem i think there is a bug in the app as with all 3 devices kodi wont shut down properly next to try is the offical app on windows 8.1
looks like the addon has had its day now for me. always buffering issues despite everything else working fine. i've tried everything and the issue persists. works fine through my laptop and pc. maybe too many people are using it now ??
(2015-10-30, 19:40)oldmankeith Wrote: [ -> ]well ive just tried my sony android tv and the same problem i think there is a bug in the app as with all 3 devices kodi wont shut down properly next to try is the offical app on windows 8.1
where are you based uk or usa ?
i think its down i keep geting error on the kodi app in the uk
uk
is anyone else having buffering issues ?
I've read and search the thread for solving the CAPTCHA problem but can't find any solution. I have Kodi installed across Fire Stick, 2nd Fire Stick, Android Phone, and Windows. So far the 2nd fire stick keep giving me the captcha error when I have the login and password entered correctly for Dish account.
Any solution for this? What does that mean the login cookie good for 5 hours and will refresh every time selecting new stream? Do I wait 5 more hours? I've selected different streams, uninstall and reinstall NBC Live Extra addon, uninstall and reinstall kodi, clear saved data, clear cache for Kodi but still error just on this 2nd Fire Stick.
Nice plug-in Can you pls add At&t U-verse as provider access to this add-on.. thanks
Any chance of adding RCN as a provider? I use my parents' account & they just switched from Comcast to RCN so as of the moment I'm screwed when it comes to using this add-on. Thank you. Very much appreciate your efforts & I'll totally buy you a beer as soon as RCN's onboard.
P.S. Unfortunately, unable to PM as I just signed up for this forum.
Anyone else getting ERROR when trying to load add on since the new wookie update? And any fix?!
Cheers
All I want to do is watch golf channel, I know it is free since it is in green, i live in the us. I am a total newbie and all i want to do is watch golf channel. when i click on it says "one or more items failed to play check the log for details" i can watch other things on nbc sports but not the golf channel. please any assistance would be very helpful
