Full Version: NBC Sports Live Extra
I can watch things in blue but cant watch the golf channel in green. i have a valid service provider but cant watch the golf channel. still getting "one or more items failed to play check the log for details"
(2015-11-03, 03:43)dgrchan Wrote: [ -> ]I can watch things in blue but cant watch the golf channel in green. i have a valid service provider but cant watch the golf channel. still getting "one or more items failed to play check the log for details"
same thing here can watch everything except the golf channel. I also have valid login and I'm from USA so don't know why it won't play
(2015-11-03, 05:42)binder420 Wrote: [ -> ]
Next time a link doesn't work, press the menu or settings button the link that didn't work and go to add on settings.
Move along to General (I think) and in there is says clear saved data or delete saved data, highlight that then go to ok and go try the link again
(2015-10-31, 08:38)gokings Wrote: [ -> ]I've read and search the thread for solving the CAPTCHA problem but can't find any solution. I have Kodi installed across Fire Stick, 2nd Fire Stick, Android Phone, and Windows. So far the 2nd fire stick keep giving me the captcha error when I have the login and password entered correctly for Dish account.
Any solution for this? What does that mean the login cookie good for 5 hours and will refresh every time selecting new stream? Do I wait 5 more hours? I've selected different streams, uninstall and reinstall NBC Live Extra addon, uninstall and reinstall kodi, clear saved data, clear cache for Kodi but still error just on this 2nd Fire Stick.
You need a DirectTV login.
Dish or Xfinity don't work well with fire stick and dns
(2015-11-02, 21:07)paddymcgin Wrote: [ -> ]Anyone else getting ERROR when trying to load add on since the new wookie update? And any fix?!
Cheers
If you are outside of the USA you need to re-activate your dns or vpn
v2015.11.3 Released
- Fixed golf channel
I just wanted to say thank you for this add-on, might be favorite Kodi add-on.
(2015-11-03, 15:13)number1fan Wrote: [ -> ]I just wanted to say thank you for this add-on, might be favorite Kodi add-on.
It is a great add on tbf
Hi guys
I am in the UK and have been reading about 'VPN Unlimited' that are doing a 3 year deal for about £12.00. I was wondering if anyone else has used this provider and if so is it any good?
Many thanks
(2015-11-03, 15:01)mackemchris Wrote: [ -> ]
Cheers
So even though I can't even get past the page with Live & Upcoming etc to see the options of what to play that would be the case?
I thought I would at least get through to see what's on but not be able to play the blue links if it was VPN issue?
Cheers
What does v2015.11.3 Released - Fixed golf channel mean? I am new to this and i am not sure what you mean by that. Am i supposed to download your latest version or changelog? And if i am supposed to changelog how do I that? Thank you for the fast response!
(2015-11-03, 23:03)dgrchan Wrote: [ -> ]What does v2015.11.3 Released - Fixed golf channel mean? I am new to this and i am not sure what you mean by that. Am i supposed to download your latest version or changelog? And if i am supposed to changelog how do I that? Thank you for the fast response!
- The golf channel stream wasn't working, now it should work.
- Download and install my repo (from the first post) and you will get the update automatically.
(2015-11-03, 15:08)eracknaphobia Wrote: [ -> ]
v2015.11.3 Released
Thank you for the fix as the gold channel is working again
I do get a problem where streams won't play "authorisation failed" quite often.
I have found if you log into the live extra webpage & play the stream there first.
Close the webpage & try the stream again in Kodi it plays fine.
Thought I would share... Works welll for me.
(2015-11-03, 23:28)eracknaphobia Wrote: [ -> ]
YOUR THE MAN eracknaphobia!!!!
