Full Version: NBC Sports Live Extra
I can't get anything to work. OP I've sent you a log. Thanks!
Thanks for the updated release on github to fix the golf stream. My only issue now is that it seems its hardcoded somewhere to stream at 1080p only (instead of what I have listed in the settings/config) which is SD 900kbps.
Is there anyway I can change this? As gorgeous as the 1080p stream looks, my connection isn't good enough to stream it and keeps crashing Sad Any help would be appreciated.
Cheers!
hello
Is there a way to rollback to 03/11/2015 as it worked for me and this one starts to play the stream and then stops.
Also the rollback feature in the configuration settings is disabled.
(2015-11-08, 16:28)Private_Pyle Wrote: [ -> ]hello
Agreed. After the addon auto-updated... it only pulls in the first part of the stream and doesn't continue to buffer/download the next piece and then kicks you out back to menu. Please fix. Thanks for your work!
Anyone got the previous version, forgot to turn off the auto update.
Hi have my Directv log in works on website fine using purevpn usa vpn. Was getting the issue the weekend when watching EPL stream would show approx 30 seconds then kick me out. Thanks for your work
I'm looking into video dropping out issue. Will update when I discover a fix.
Thanks eracknaphobia you are a star
It is not just the video drop issue, the problem is that it doesn't matter I set it on 900k or sd or 2200 or 400, but it only showing 720p when playing.
(2015-11-09, 17:11)dashtekahe Wrote: [ -> ]It is not just the video drop issue, the problem is that it doesn't matter I set it on 900k or sd or 2200 or 400, but it only showing 720p when playing.
Read post #2048
(2015-11-09, 16:49)gavp1981 Wrote: [ -> ]Thanks eracknaphobia you are a star
Indeed. Truly appreciate your efforts, eracknaphobia!
I'm not sure if it is just me...
I find the streams play so much smoother using this app as opposoed to the streams on the NBC website.
Why do streams play so much better in Kodi?
Also, I wondered if I could talk you into working on an app for beIN Connect.
Not sure if it is feesable?
In any case keep up the great work eracknaphobia.
(2015-11-09, 22:05)MatLCFC Wrote: [ -> ]I'm not sure if it is just me...
Because the app is using the ios HLS streams and not the flash stream the website uses
I've tried my mom's and cousin's DirectTV login and my dad's Xfinity login, all three do not get me streams. They all say make sure login and password are correct. Am I doing something wrong?
The chemist are you using a vpn?
