(2015-11-10, 04:38)thechemist Wrote: [ -> ]I've tried my mom's and cousin's DirectTV login and my dad's Xfinity login, all three do not get me streams. They all say make sure login and password are correct. Am I doing something wrong?
This is purely guesswork on my part but my Direct TV login works every time (touch wood), make sure you have clear saved data enabled in the addon settings and in the stream settings I'd try making sure the CDN setting is most appropriate for your location, if you're east coast obviously it should be set to east and vice versa with west coast, if you're midwest and beyond you may have to experiment with the CDN for you, I have no proof other than anecdotal evidence from my experiments but this setting does seem to effect the addons performance.
is anyone able to watch 3pm premier league kickoffs with this as i have not been able to without major buffering issues for a while. just wondering if the problem is on my end or not. thanks guys
(2015-10-10, 11:15)dexg1 Wrote: [ -> ]I dont use vpn just dns which is ublockr.net. no need to change account to US or the time like some have said on here
Hi mate, sent you a PM & an email, give us a shout back, cheers
v2015.11.11
- Fix video streams dropping
- Brought back stream quality selection via dialog
Biggest change here is now you will be given a choice of what stream qualities are available for the particular stream.
This is good for two reasons:
1. It allows me to fix the dropping issue by going into the master file and grabbing the needed cookies before playing the stream.
2. It will give you a broader selection of qualities so you should be able to find one that closer suits your internet speeds
*Note that streams below 100 kbps are usually audio only
Any updates on the SmartDNS+comcast issues? I'm still getting authorization errors
v2015.11.12
- Fix bug that only affected fresh installs
Thanks to mulliganman for discovering the bug
Can we please introduce "Automatically Play Best Stream" in settings within this addon as well please?
(2015-11-12, 18:11)siuside Wrote: [ -> ]Can we please introduce "Automatically Play Best Stream" in settings within this addon as well please?
Yeah, i was waiting for that to come up. I will add this at some point in the near future.
Is there anyway of adding in the option to enter captcha for kodi on android?
Still have the issue of bad user and password but it works fine on kodi on a Mac. Using Comcast xfinity logon.
Thanks again for the hard work.
thanks for the updates. such an awesome addon. all we need now is NBC to pull their finger out and sort the football out and provide stable streams !! thanks again, awesome work
is 720p the max for streams or can we get 1080p as well. I have fast enough internet and would love if 1080p can be added as a quality selection as well
(2015-11-12, 20:42)binder420 Wrote: [ -> ]is 720p the max for streams or can we get 1080p as well. I have fast enough internet and would love if 1080p can be added as a quality selection as well
It depends on the stream. What's listed once you select an event is what is available. Golf and the Dan Patrick show both air 1080 versions usually under the 4296 kbps. However, the majority of streams only go to 720 ~ 3599 kbps.
Thanks for the update. The choose quality stream is a great addition.
