(2015-11-12, 18:50)swd72000 Wrote: [ -> ]Is there anyway of adding in the option to enter captcha for kodi on android?
Still have the issue of bad user and password but it works fine on kodi on a Mac. Using Comcast xfinity logon.
Thanks again for the hard work.
+1, please answer eracknaphobia, love the addon but this would be so good. Thanks
(2015-11-12, 20:52)eracknaphobia Wrote: [ -> ] (2015-11-12, 20:42)binder420 Wrote: [ -> ]is 720p the max for streams or can we get 1080p as well. I have fast enough internet and would love if 1080p can be added as a quality selection as well
It depends on the stream. What's listed once you select an event is what is available. Golf and the Dan Patrick show both air 1080 versions usually under the 4296 kbps. However, the majority of streams only go to 720 ~ 3599 kbps.
Thanks for the explanation eracknaphobia
Live in UK, have smart dns on my router is that good enough or do I need a vpn for kodi app
(2015-11-10, 16:20)gavp1981 Wrote: [ -> ]The chemist are you using a vpn?
I am not using a VPN. I'm in CA so i wouldn't think i would need to
I'm now getting failed to authorize, I know I'm putting in the username and password correctly because i can login to directTV.com
(2015-11-13, 00:03)chilindude Wrote: [ -> ] (2015-11-12, 18:50)swd72000 Wrote: [ -> ]Is there anyway of adding in the option to enter captcha for kodi on android?
Probably not going to happen. If it were easy, I would have already done it.
(2015-11-13, 04:27)thechemist Wrote: [ -> ] (2015-11-10, 16:20)gavp1981 Wrote: [ -> ]The chemist are you using a vpn?
I did a quick test with the Direct TV credentials I wrote the code with and was able to login in successfully. Have you tried to login to the NBC live extra website? If it doesn't work there then it won't work here.
(2015-11-13, 15:29)eracknaphobia Wrote: [ -> ] (2015-11-13, 00:03)chilindude Wrote: [ -> ] (2015-11-12, 18:50)swd72000 Wrote: [ -> ]Is there anyway of adding in the option to enter captcha for kodi on android?
So as of now there is no way of having it work with xfinity using VPN/DNS?
This addon is meant for people in the USA, just like the official app. If you are using a bypass mechanism then expect varying results. It's not within the scope of this project to help bypass any geo restrictions.
(2015-11-13, 15:29)eracknaphobia Wrote: [ -> ] (2015-11-13, 04:27)thechemist Wrote: [ -> ] (2015-11-10, 16:20)gavp1981 Wrote: [ -> ]The chemist are you using a vpn?
I have the directTV app on my miniX and i am signed in and able to watch live TV there. I have put in the login and password many times to confirm the correctness. I moved to LA from Oakland and want to watch Warrior games on CSN Bay Area
(2015-11-13, 16:47)eracknaphobia Wrote: [ -> ]This addon is meant for people in the USA, just like the official app. If you are using a bypass mechanism then expect varying results. It's not within the scope of this project to help bypass any geo restrictions.
I really don't understand why people like standing common sense on its head. It has been said on here over and over again that this addon is designed for US residents with valid login details. ....And yet some newbies keep coming on here asking dumb questions without bothering to read the very 1st page of the forum and the attendant warning by eracknaphobia.
Another resipository forum I subscribed to (Shani-08) has just been taken down by DMCA because of these kind of people and their ludicrous questions . If you are not in the US and want to access this addon , logic and common sense should tell you that asking those sort of questions on here(VPN/DNS questions ) will be against the terms and conditions, and it risks spoiling it for everyone else.
Please take those questions somewhere else, as someone once said,....THE GOOGLE IS YOUR FRIEND!!! #rantover#
(2015-11-13, 16:55)thechemist Wrote: [ -> ] (2015-11-13, 15:29)eracknaphobia Wrote: [ -> ] (2015-11-13, 04:27)thechemist Wrote: [ -> ]I am not using a VPN. I'm in CA so i wouldn't think i would need to
I'm not familiar with the direct tv app. Go here (
http://www.nbcsports.com/live-extra) and try to login with your direct tv account, if it works then we can say there's a problem with the addon.
(2015-11-13, 17:22)eracknaphobia Wrote: [ -> ] (2015-11-13, 16:55)thechemist Wrote: [ -> ] (2015-11-13, 15:29)eracknaphobia Wrote: [ -> ]I did a quick test with the Direct TV credentials I wrote the code with and was able to login in successfully. Have you tried to login to the NBC live extra website? If it doesn't work there then it won't work here.
I'm not familiar with the direct tv app. Go here (http://www.nbcsports.com/live-extra) and try to login with your direct tv account, if it works then we can say there's a problem with the addon.
I am able to login in using my cousin's directTV account and my dad's Xfinity account
(2015-11-13, 17:43)thechemist Wrote: [ -> ] (2015-11-13, 17:22)eracknaphobia Wrote: [ -> ] (2015-11-13, 16:55)thechemist Wrote: [ -> ]I have the directTV app on my miniX and i am signed in and able to watch live TV there. I have put in the login and password many times to confirm the correctness. I moved to LA from Oakland and want to watch Warrior games on CSN Bay Area
Just to make sure we're on the same page, you are selecting the appropriate provider when entering your credential? If your are selecting the correct provider when attempting a log I guess you could pm me the credentials and I could test them on my end. Not really sure how else to debug this because, like I said, the direct tv account i tested is working.
(2015-11-13, 18:03)eracknaphobia Wrote: [ -> ] (2015-11-13, 17:43)thechemist Wrote: [ -> ] (2015-11-13, 17:22)eracknaphobia Wrote: [ -> ]I'm not familiar with the direct tv app. Go here (http://www.nbcsports.com/live-extra) and try to login with your direct tv account, if it works then we can say there's a problem with the addon.
It works now but last night it was not. I had tried on my computer and my tv box. The add-on was updated and everything. I'll chime in tomorrow when the Warriors play to see if i get failed to authorize again
(2015-11-13, 01:30)lewis277845 Wrote: [ -> ]Live in UK, have smart dns on my router is that good enough or do I need a vpn for kodi app
Stick with dns. vpn is too slow
Does anyone else find that 2015.11.6 causes less to no buffering than to 2015.11.12? Mine buffers every 5 minutes or so on 3200 kbps, however, on 2015.11.6., I can go about an hour without buffering
