Full Version: NBC Sports Live Extra
Anyone still having an issue with the streams dropping? Mine drops after 2 minutes. I'll post logs when i get a chance.
p.s I'm running the 11-12 build
(2015-11-18, 06:22)Punknurface Wrote: [ -> ]Anyone still having an issue with the streams dropping? Mine drops after 2 minutes. I'll post logs when i get a chance.
Seems that it may be a cookie issue with ffmpeg. This seems to effect all but the Windows version of kodi.
I will test Jarvis (16 alpha) and see if the problem exists there too.
I just got the Amazon firestick with Kodi. The NBC Sport Extra was already installed, but i can't log in with my information? I have no problem doing so on a computer.
Is this add on new and updated so i have to install it again??
Link to my log files below.
http://xbmclogs.com/p8i5ldceh
This is issue is happening on a Windows PC and an Openelec raspberry pi
I have managed to get a log in but it doesn't appear to work, does anyone know if these log ins are a bit hit and miss? I am in the uk using a dns
Hi yes mine keeps droppng after two mins on my ouya,i'm using the latest version on kodi 14.2.
Every 2 mins for me.thats on a windows pc
I don't seem to have permissions to send you a private message but I can email you credentials for RCN if you want to get that provider working.
My email is damien.biggs at gmail.com
Working absolutely fine for me today, Windows 7 PC and Kodi 14.2
Live streams drop out every 1:58 seconds on the latest version. Tested today on EPL and just on the College Football streams. Rolled back to an earlier version I had saved and my streams do not drop out now. Replays and vod did not drop out on latest version only live blue streams.
Kept on dropping stream this morning as well after about 2 mins while trying to watch EPL.
Gave up after 3-4 attempts and used web browser instead.
Latest addon version, 16.2 on Windows 7 using Cox login in the US.
Mines working fine. If its dropping connection try using a different dns/vpn provider. I managed to watch man utd/watford, WBA/Arsenal and man city/Liverpool and didnt have a problem. Im running openelec 6.0.0/ kodi 15.2
(2015-11-20, 21:49)villan0906 Wrote: [ -> ]I have managed to get a log in but it doesn't appear to work, does anyone know if these log ins are a bit hit and miss? I am in the uk using a dns
try a vpn instead. I used smartdns for a while but it started to fail so switched to vpn, no problems since.
Rolled back to a previous version ,works fine and dandy.
Any fix for the drop out of stream every couple minutes? Cheers
