Full Version: NBC Sports Live Extra
No VPN. Cox subcriber here in So Cal.
For some reason, Cox was not broadcasting game on TV Live Extra channel...
have you tried running openelec from a usb stick on your pc? also try with only the nbc addon enabled, see if any other addons are affecting the network. I only watch the man city games on a direct tv login but never had a drop out. I used to have some issues when using a smartdns but a vpn sorted that.
StuCONNERS,
I will use either one of my browsers from now on. Validation and streams work without a glitch there.
Hi thanks this add-on it is amazing . I just have a quick question is there a way to lower the stream quality as HD streams cause me some buffering issues. Thanks
Hi does anyone have the previous version ,if so could send it me.This version cuts off after 2 mins.Thanks
(2015-12-04, 22:27)berty98 Wrote: [ -> ]Hi does anyone have the previous version ,if so could send it me.This version cuts off after 2 mins.Thanks
I don't think it has anything to do with a previous version. mine has started to do the same thing today.
hoping that it's something that will clear itself.
if you do want to rollback, and you've been using the repo,
you should be able to find previous versions in your addons/packages folder.
Here's have I've tricked this addon into working for me... with the stream cutoffs. Login with the latest version from the depo. Then have it authenticate with that verison (start a stream). After the stream cuts off, uninstall the updated version and use a version from August. The new version's authentication token will then allow you to use the old version which doesn't cut off after two minute to watch a full length match without any problems. Just be sure when switching between versions that your login information is correct, especially when it comes to selecting a provider.
When you use the version from August how do you stop the addon auto updating to the version in the Kodi repo please?
(2015-12-05, 18:16)VanZan Wrote: [ -> ]When you use the version from August how do you stop the addon auto updating to the version in the Kodi repo please?
Disable the repo from settings .
You can disable addons auto updating by using in the side menu while in the addons settings page.
Brand new Amazon Fire TV, Kodi 15.2, NBC Sports Live Extra 2015.11.6, streams cut off after a few seconds.
Will you be adding Centurylink Prism to the cable provider list anytime soon?
(2015-12-06, 06:57)nvtimit Wrote: [ -> ]Will you be adding Centurylink Prism to the cable provider list anytime soon?
Please read the first post.
Hi, Trying to install from zip file, I get the file ok and then I go to "install from repository" select nbc sports and select "install" then I get the message "failed to install a dependency". Any help would be much appreciated, and please treat me like a complete idiot. thanks
(2015-12-06, 08:42)bry- Wrote: [ -> ]
I saw the first post but I was hoping that I wouldn't have to make 9 more junk messages before getting an answer to my issue.
