Full Version: NBC Sports Live Extra
(2016-01-29, 23:19)JPW1979 Wrote: [ -> ]Hi, does anyone know where I can get a log in?
I suggest you read the first post. Pay close attention to the big bold letters.
After yesterday's update I get failed to authorize through my direct tv account can anyone advise please, was working before the update.
Thanks for your support, had to change my login details, all working now
(2016-01-30, 02:37)derekg Wrote: [ -> ]After yesterday's update I get failed to authorize through my direct tv account can anyone advise please, was working before the update.
I just test the Direct TV login and it appears to be working on my end. Are you sure your settings are correct? Did your provider setting get changed? If not post a log and I'll take a look.
(2016-01-29, 23:22)eracknaphobia Wrote: [ -> ]
Ha, apologies.....didn't read the first page as I'm sure loads have done, didn't mean to p*as you off.
HI
How do i install the Eracknaphobia repo on my gbox ?
Is there a url to add the file source ?
I have no update on the Kodi Repository.
(2016-01-30, 12:03)rossie250 Wrote: [ -> ]HI
Repo posted in the first page, then you can install repo from zip file.
Hi, I just checked with my Directv account and all worked fine, as eracknaphobia suggested check your settings, I've known mine to change after an update (although it hasn't happened for a while)
Addon still working perfect, thanks for the great work!
Would you consider working on a similar addon for fox sports, i think they use HLS streams now?
have you a dns or a vpn
(2016-01-30, 18:51)dexg1 Wrote: [ -> ]
this is needed in the uk passwords are easy 2 get
(2016-01-30, 19:11)dexg1 Wrote: [ -> ]
I strongly suggest u do this via pm as you are going against the explicit instructions of eracknaphobia.
(2016-01-30, 13:50)dtsexpert Wrote: [ -> ]
Not sure where I'm going wrong here.
I save the repo on the first page to a USB stick file manager/external storage/erackrepo/ then get addon.xml & icon.png
or I go to settings/addons/installfromzip/externalstorage/erackrepo/ and I get no options at all....
Could somebody help ? Im sure I'm getting it all wrong somehow.
save the .zip file somewhere and then in settings/addons/install from zipfile and browse to where ever you saved the repo zip. once the repo is installed you go to install from repo and find the addon there and install it
hope that helps.
sorry... I don't get it.
The file I am given on page one is this (the alternative to downloading from the Kodi Repo) : repository.eracknaphobia-master
Its a folder not a zip file.
Am I downloading the wrong one ? its the only file I'm given so I'm guessing Im doing the wrong thing with it.
I should add I'm using a matricom gbox q so this is not a direct download, this is why i add it to a USB stick the try to install it on the box.
Im using a macbook to download it, could that be the problem ?
Sorry to be a pain!
(2014-10-25, 14:48)rushtona Wrote: [ -> ]quality add on working here in the uk, only issue I have it is very jumpy on and k/b speed at all? any ideas?
How did you get a login?
