(2016-03-04, 22:46)Citybluematt Wrote: [ -> ]I'm using a droidbox t8
Here's my log
Http://xmbclogs.com/pdqrurtxo
Yep same mktime argument out of range error. I think we've nailed this one down. Thanks for the log!
btw, your link should be
http://xbmclogs.com/pdqrurtxo, to me a minute figure out the b and m were switched.
(2016-03-04, 22:55)eracknaphobia Wrote: [ -> ] (2016-03-04, 22:46)Citybluematt Wrote: [ -> ]I'm using a droidbox t8
Here's my log
btw, your link should be http://xbmclogs.com/pdqrurtxo, to me a minute figure out the b and m were switched.
Haha sorry I've edited it now anyway. But sounds like you've figured it out. Thanks
I am running Kodi on my Galaxy S6 which has a 64 bit processor (Aarch64) and am getting the same error.
My log file is at
http://xbmclogs.com/pnztcm8ob
Getting the same script error when trying to access live and upcoming. Is there a solution I can apply.
If so could anyone point me in the right direction to achieve this. Thanks.
Well I've tested a fire tv, fire stick, and pc (all on version 2016.2.3.2 | Kodi 15.2) and can't get the error to pop. Since the error is time related I would try maybe changing your system clock to 12 hour eastern standard time and see what happens.
(2016-03-05, 14:44)eracknaphobia Wrote: [ -> ]Well I've tested a fire tv, fire stick, and pc (all on version 2016.2.3.2 | Kodi 15.2) and can't get the error to pop. Since the error is time related I would try maybe changing your system clock to 12 hour eastern standard time and see what happens.
Hi done that and I got in to the live section but when I clicked on a game I get the script error message, what has changed so much as last weekend it was fine ?
I wonder if this error is related to NBC closing down certain ways of bypassing the geo restrictions rather than a fault with the addon?
For the record its working fine on my Windows 7 desktop (still) running Kodi 14.2 and also my Windows 10 Surface Pro 4 running Kodi 16.0,
so either its certain Android boxes which I assume would be a nightmare to track down and fix or a geo-restriction error which you can do nothing about.
Genius! Works. Changed to eastern time and all is good. Simple fixes are the best. Thanks eracknaohobia!
Update. Not tried an actual game stream yet! Oops.
(2016-03-05, 15:48)madds78 Wrote: [ -> ]Genius! Works. Changed to eastern time and all is good. Simple fixes are the best. Thanks eracknaohobia!
Yep all works a treat! Thank you.
Thanks. Changed the time to Eastern standard. This enable the live and upcoming section.
However live login links give a script error. (Blue links) the rest play perfectly.
One step closer lol.
Thanks again.
(2016-03-05, 16:05)daveyham Wrote: [ -> ]Thanks. Changed the time to Eastern standard. This enable the live and upcoming section.
Thanks again.
I had a bit of an issue and noticed it reverted back to the default supplier other than comcast. Bright something. Changed that and got in. Watching tot / ars as we speak.
Thanks for the advice now working great. Thanks also for all the work you have put in on this add-on, much appreciated.
Thanks Erack,your a star mate.
