Full Version: NBC Sports Live Extra
Yes changed TV provider to correct one and re entered user and pass.
Gets into live section but still not able to play live stream. Tot/are.
Oh well I'll try later.
(2016-03-05, 16:31)daveyham Wrote: [ -> ]Yes changed TV provider to correct one and re entered user and pass.
Same here. Not sure whether the issue is with the Add on or my log in details now
For the people who are getting the error can you please post the following info:
- Your local timezone
- Your clock configuration (12h or 24h)
Local timezone
London GMT + 0.00
12h
(2016-03-05, 16:43)Citybluematt Wrote: [ -> ]
Test you login credentials on the website to verify you can open streams.
(2016-03-05, 16:47)eracknaphobia Wrote: [ -> ]
Getting system error - identity manager on the website. Will the failure to log in on the website be to do with me being in the uk though?
Add on appears to have suddenly started working
Yes can login via the website ok and watch streams.
Local time zone London
Format 24 hour.
I can also login via the official standalone app no problem.
Format 24hour.
Add-on let's me login in to live and upcoming only after I change the time zone to Eastern standard, however live streams result in error.
(2016-03-05, 17:38)daveyham Wrote: [ -> ]Yes can login via the website ok and watch streams.
Format 24 hour.
Format 24hour.
Mines started working, out of the blue. Wouldn't let me log in earlier. But I'm watching the football now
Ok me too via showcase. No time alterations required either.
Watching Newcastle game.
Still error on the the live and upcoming with no time change.
I'm watching via live & upcoming. It's all a bit strange
Eracknaphobia, any chance of you working on a similar addon for fox sports in the future?
Either way keep up the great work on this app, its much appreciated.
Changing time zone to eastern time worked fine for me on my Fone so I'll try it on my t8 droidbox. Cheers eracknaphobia
Unticked automatic and ticked eastern time and works on live section on my t8 droidbox! Nice 1 ur a legend!
