hello all, newbie here. i am still having issues with streams dropping every 2-3 minutes. i've been told to try installing an older version, specifically one from august of last year. is there a link where i can get the older zip files? thanks.
Update 2016.3.9 Released
- Fix for time error attempt #3
Please tell me this one works
(2016-03-08, 23:31)eracknaphobia Wrote: [ -> ]Update 2016.3.9 Released
That works perfectly! Thank you so much for this most excellent add on.
Hi well done this had fixed the time issue, one problem that I do have which may not having anything to do with the add-on is when I click on a live stream sometimes I get failed to authorise message appears but if I click on the same stream a few times it lets me in
(2016-03-08, 23:50)talkingoldfish Wrote: [ -> ] (2016-03-08, 23:31)eracknaphobia Wrote: [ -> ]Update 2016.3.9 Released
Great work. I will also give it a go when I get home from work and let you know
Works here, thanks again.
Works like a dream for me now also. Great work
Yes working great, my thanks yet again to the developer.
This works great,but is there anyway you can add the option to choose the video quality as it has taken this away."Automatically play best stream" option in config settings,always seems to cause buffering in the past.
(2016-03-10, 22:13)donjuan400 Wrote: [ -> ]This works great,but is there anyway you can add the option to choose the video quality as it has taken this away."Automatically play best stream" option in config settings,always seems to cause buffering in the past.
If you disable this option it will let you select the video stream quality manually.
(2016-03-10, 22:26)eracknaphobia Wrote: [ -> ] (2016-03-10, 22:13)donjuan400 Wrote: [ -> ]This works great,but is there anyway you can add the option to choose the video quality as it has taken this away."Automatically play best stream" option in config settings,always seems to cause buffering in the past.
It does,sorry to waste your time.Keep up the great work.
Working a treat now eracknaphobia. Good work!
I get a lot of buffering from the live streams, even at low quality settings.
I've tried streaming other sites, such as SALTS through my VPN and they play fine with buffering, seems to be isolated to NBC Sports Addon.
It used to work great around about a month ago, not sure if it has updated since then.
Anybody else having issues?
Check on the first page to see if yours has the same version on.
(2016-03-12, 19:49)donjuan400 Wrote: [ -> ]Check on the first page to see if yours has the same version on.
2016.3.9 is installed which is the latest. I must be missing something here as it seems to work fine for others. I'll keep tinkering.
