Full Version: NBC Sports Live Extra
(2016-09-10, 15:41)motherboard Wrote: [ -> ]Can anybody tell me where I need to do the above please?
Inside the nbc addon file open up resources and open the globals.py file and edit the above by removing the # from the two lines
Can't see this option. I'm on android kodi. If I press menu on the app the option is not there. Please help!
Just done it on android you need to use es file explorer. Strange this has been working spot on and then nothing today
(2016-09-10, 15:45)K1rky84 Wrote: [ -> ]
Thanks mate managed it. I just removed the one # from the second line seems to have worked ok. Do you need to put it back in later?
Where in system do you go? Thought I found it but no luck. Appreciate any help
I'm also struggling to find the file on Kodi, where is it please?
(2016-09-10, 16:11)Foxy38 Wrote: [ -> ]Where in system do you go? Thought I found it but no luck. Appreciate any help
Android/data/org.xbmc.kodi/files/xbmc/addons/plugin.video.nbcliveextra/resources
What Valve said above
I'm having same issue with football streams. I edited globals.py file but still not playing. Log shows a http 403 error.
Replays and other streams working in kodi add-on. Football streams are working via nbcsn live android app bit not kodi add-on
http://pastebin.com/B7JzzSx7
Valve are your games playing 720 today? I normally get 1080p is it normal to vary
(2016-09-10, 16:38)K1rky84 Wrote: [ -> ]Valve are your games playing 720 today? I normally get 1080p is it normal to vary
Yeah same here, getting slight buffering aswell.
(2016-09-10, 16:42)Valve Wrote: [ -> ]
Not had any problems with buffering but 1st time I've noticed it drop from 1080p to 720p
Still a decent picture mind I'm far from complaining lol
First, thank you for your posts. I have also had this issue with "failed to authorize" and somehow got it to work for the Manchester United game (the problem is back again for the 3pm games).
To answer your question, I noticed that my games are at 720p as well.
By the way and sorry for the off topic, but I'm pretty sure you probably will be able to help me, this post here, do you know why I can play this add-on with a DNS service, but watchESPN doesn't work?
Is this setting outside of kodi? Sorry for stupid questions just can't find bloody thing lol
