Full Version: NBC Sports Live Extra
(2016-09-18, 15:03)chrisnewton Wrote: [ -> ]
(2016-09-18, 14:17)nicknack35 Wrote: [ -> ]Well if your using the Android NBC Sports App then its Wi Fi only and if your Wi Fi signal speed is poor then your not going to get a very good pic i tried on my last T8 V3 and the pic was rubbish due to the Wi Fi now im using The minix neo u1 with Fake Wi Fi in which the app thinks im connected to Wi Fi when really i get ethernet speeds and the pic is decent. I need to change my router also to a dual band
It's not WiFi only my shield is connected via ethernet and works great
Hmmmm Well when i have used the App when its used by Ethernet it always asked me to switch so it can use data charges which is Wi Fi only. Which NBC Sports app you using?
It's definitely not WiFi only. There is an official NBC Live Extra APP on the Amazon store for those with FireTV devices, it can be used on a wired FireTV box or a Firestick. I think you may be talking about the unofficial APK, not the official APP.
Hi I've got the nbc app on my shield working spot on but my android q box upstairs not so good. When I click on a stream it starts to load then just get a blank black screen. Anyone any idea why?
(2016-09-18, 15:27)nicknack35 Wrote: [ -> ]
I'm using the official app mate
Yea im talking about the unofficial APK. Well how do you get the Official App on the Shield lol
(2016-09-18, 14:49)ahammersfan Wrote: [ -> ]
(2016-09-18, 13:47)nicknack35 Wrote: [ -> ]I always thought when using the App the pic quality was dependent on how good your Wi Fi strength was to how good of a picture you would get
My box is connected by Ethernet - how does wifi make any difference??
Also, nothing wrong with my speed and the picture via the app is poor (the official app by the way)
(2016-09-18, 15:41)nicknack35 Wrote: [ -> ]Yea im talking about the unofficial APK. Well how do you get the Official App on the Shield lol
Just Google nbcsn sports apk
Well i have a direct tv account but on my android box i cannot get the app off playstore i have to get it off APKpure and install it that way but i cannot use the app via ethernet only Wi Fi. i can use it via ethernet now but never was able to
(2016-09-18, 15:59)ahammersfan Wrote: [ -> ]
Well if there is nothing wrong with your speed then you should get a decent pic the only time your not going to get a HD stream if your net is not fast enough other wise you should get a decent pic
(2016-09-18, 16:18)nicknack35 Wrote: [ -> ]
(2016-09-18, 14:49)ahammersfan Wrote: [ -> ]My box is connected by Ethernet - how does wifi make any difference??
Well it is fast enough (used to get 1080 on addon no problem) and the quality is lower end of SD.
Well there is something a miss if you could get 1080 on kodi but cannot on the official app You would of thought it been the other way around
If people on the shield are getting a decent pic then something is deffo wrong lol
(2016-09-18, 16:34)nicknack35 Wrote: [ -> ]Well there is something a miss if you could get 1080 on kodi but cannot on the official app You would of thought it been the other way around
My thoughts too - I was thinking there may be a quality setting in the app but I can't find one.
Well when i got my direct tv account i was told if your wi fi is good enough then your pic will be ok cause im not sure what app im using cause i had to get it off apkpure and that app is wi fi only not ethernet and i tested my wi fi on my last android box and it was rubbish and then i tried via ethernet and i could not get the stream to play. But since i have changed my box to minix neo u1 the stream is great via ethernet cause i have fake wi fi
(2016-09-18, 16:40)ahammersfan Wrote: [ -> ]
Where did you get the official app from and what box you using? cause the NBC extra live app is not available from play store i had to install APKpure on my box to install it from there?
