Full Version: NBC Sports Live Extra
(2016-09-18, 17:53)nicknack35 Wrote: [ -> ]What VPN you using Chris and you using it on your Shield or doing it via the router?
You can use any VPN that has US servers, I use CyberGhost VPN which is free.
Could you please stay on topic? This is a thread about the NBC Sports Live Extra add-on, not a discussion about how to bypass geo restrictions which this site will not tolerate.
(2016-09-18, 17:00)nicknack35 Wrote: [ -> ]
(2016-09-18, 16:40)ahammersfan Wrote: [ -> ]
(2016-09-18, 16:34)nicknack35 Wrote: [ -> ]Well there is something a miss if you could get 1080 on kodi but cannot on the official app You would of thought it been the other way around
My thoughts too - I was thinking there may be a quality setting in the app but I can't find one.
Where did you get the official app from and what box you using? cause the NBC extra live app is not available from play store i had to install APKpure on my box to install it from there?
Just googled it and found it that way
(2016-09-18, 17:58)OTinley Wrote: [ -> ]Could you please stay on topic? This is a thread about the NBC Sports Live Extra add-on, not a discussion about how to bypass geo restrictions which this site will not tolerate.
Your right... Sorry
Any word from the boss man on an update? Eraknaphobia we need u man lol
can another help with a log file error on this app and if so how I go about doing it thanks
(2016-09-19, 20:53)wilks12003 Wrote: [ -> ]can another help with a log file error on this app and if so how I go about doing it thanks
The app or the addon?
addon in kodi mate
(2016-09-19, 22:03)wilks12003 Wrote: [ -> ]addon in kodi mate
It's not working anymore mate - changes at NBC means it is finished unless developer can find a workaround, All discussed above.
Ok thanks for the info, just checked back and read apkpure is a way round is that right? And yes I'm in the UK.
(2016-09-20, 14:04)wilks12003 Wrote: [ -> ]Ok thanks for the info, just checked back and read apkpure is a way round is that right? And yes I'm in the UK.
No idea mate- anyone else?
You can download and install directly or sideload APK`s from apkpure,1mobilemarket and apkmirror
(2016-09-20, 18:36)j2220 Wrote: [ -> ]
What does this give you that the app you can find on google doesn't?
(2016-09-20, 20:10)ahammersfan Wrote: [ -> ]
There considered to be more trustworthy sources you can download and install the apps directly onto your device , a massive choice of apps in one place etc
I use unblockr DNS in Uk £20 per year works perfect for me on nvidia WiFi and Ethernet direct TV acc
