it doesnt seem to be working with any log in ive got comcast and direct tv and nothing
(2016-10-19, 20:22)600bandit Wrote: [ -> ]Hi eracknaphobia, Just updated to 2016.10.19 and now I cant logon? (DirectTV) Anyone else had this problem, I've tried on android box and windows 10...
... Or is it possible to get 2016.10.17 that was working. Thanks
https://github.com/eracknaphobia/repo.er...nliveextra
I've added a quick link to archive versions on the first post as well.
Add-on is not working gives error also audio needs to be fixed in 10/17 add-on.
(2016-10-19, 21:02)everlast Wrote: [ -> ]Add-on is not working gives error also audio needs to be fixed in 10/17 add-on.
Can somebody upload an error log? Never said the audio was fixed or fixable.
Add-on just released is not working gives log error so put 10/17 back even tho some streams have no audio thanks for the add-on
Post 2987 posted on audio issue but latest release gives log error thanks for all you do.
Kodi doesn't find a playable audio stream inside the m3u8, not really concerned about that at the moment. I'm trying to figure out why people can't login on the newest version. If someone could post a log file with an error that would be helpful.
(2016-10-19, 21:52)emilsvennesson Wrote: [ -> ] (2016-10-19, 21:16)eracknaphobia Wrote: [ -> ]Kodi doesn't find a playable audio stream inside the m3u8, not really concerned about that at the moment. I'm trying to figure out why people can't login on the newest version. If someone could post a log file with an error that would be helpful.
Let me guess: http://trac.kodi.tv/ticket/16670
Unfortunately that does seem like it is the issue. I'm hoping there is another stream type i can use as I currently go for the ios stream but there are 4-5 different streams listed if i'm lucky there is a legacy m3u8 stream that will play nice with kodi for the time being.
Update 2016.10.19.2 Released
- Fixed repo bug
(2016-10-19, 21:01)eracknaphobia Wrote: [ -> ] (2016-10-19, 20:22)600bandit Wrote: [ -> ]Hi eracknaphobia, Just updated to 2016.10.19 and now I cant logon? (DirectTV) Anyone else had this problem, I've tried on android box and windows 10...
Thanks for that eracknaphobia
Back up and running on 2016.10.17
(2016-10-19, 21:56)eracknaphobia Wrote: [ -> ] (2016-10-19, 21:52)emilsvennesson Wrote: [ -> ] (2016-10-19, 21:16)eracknaphobia Wrote: [ -> ]Kodi doesn't find a playable audio stream inside the m3u8, not really concerned about that at the moment. I'm trying to figure out why people can't login on the newest version. If someone could post a log file with an error that would be helpful.
I removed the QualityLevels(7000000) part from the stream link and it will play audio and video in an external player like android MX player but not in kodi
i am still getting failed to authorize. I tried removing the # on the old version and that didnt work and on the new update this doesnt seem to be there anymore but i am still getting failed to authorize
(2016-10-19, 22:54)Workcress Wrote: [ -> ] (2016-10-19, 21:56)eracknaphobia Wrote: [ -> ] (2016-10-19, 21:52)emilsvennesson Wrote: [ -> ]Let me guess: http://trac.kodi.tv/ticket/16670
So can you confirm what this means in terms of how we might get audio when launching links inside of Kodi? For instance, I am not clear on how I would get the audio and video to work with another external player. Sorry for my noob question, just not clear how I might get from the current status of having no audio when I watch a link on the app in Kodi and having a link that does? Thanks so much!
thanks
eracknaphobia the 2016/10/19.2 is working fine for me using comcast login sound ok
