Not getting any audio on the Dan Patrick show logging in with a time warner account is anyone else having the same issue using version 2016.10.19.2
Mine is a direct tv account using datho vpn that is still failing to authorise
Update 2016.10.20 Released
- Attempt to fix no audio in streams (legacy streams are used if available)
- Added Playstation Vue to the providers list
Unable to connect to your repo through kodi. Is it down at the moment? Installed the latest version manually
(2016-10-20, 22:13)pedro3187 Wrote: [ -> ]Unable to connect to your repo through kodi. Is it down at the moment? Installed the latest version manually
Shouldn't be. I just updated a remote machine and it connected without an issue.
(2016-10-20, 22:18)pedro3187 Wrote: [ -> ]Just tried again with same results. Here is a log -
https://paste.ubuntu.com/23355687
Thanks for your help
The repo is hosted on github. I don't have control over anything connection wise.
21:00:59 T:140166450636544 ERROR: CRepositoryUpdateJob[repository.eracknaphobia] failed read checksum for directory 'https://github.com/eracknaphobia/repo.eracknaphobia/raw/master/addons.xml'
21:01:04 T:140165935372032 ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
Can you get to the url through your browser?
https://github.com/eracknaphobia/repo.er...addons.xml
Yes I can access it via my browser. I wonder if it has anything to do with the vpn I'm running. I will test again tomorrow when I have more time
(2016-10-20, 21:56)eracknaphobia Wrote: [ -> ]Update 2016.10.20 Released
Thanks for this. I am hoping that it fixes the no audio on the Boston Celtics games I get through my Xfinity provider, but since the preseason games do not seem to show up under replays, I can't test until the next game next week. If you got this working you most definitely have beer money coming your way. Cheers!
Thanks for all the hard work, Erack. Happy to buy you a few lagers, but Comcast xfinity login still isn't working with the latest release 10.20.16 (at least for me). This was a fresh install.
"Please verify that your username and password are correct"
I'm on latest version 2016.10.20 using Comcast/Infinity and everything works fine. Tested all live blue links, replays, everything is working 100% in glorious 1080p. Thank you so much
Sos if mentioned before but mine only plays for 2 mins and kicks me out on kodi. Have the latest version installed. Swapped the accelerations about off/on. Still no joy
(2016-10-21, 12:54)bluenose79 Wrote: [ -> ]I'm on latest version 2016.10.20 using Comcast/Infinity and everything works fine. Tested all live blue links, replays, everything is working 100% in glorious 1080p. Thank you so much
Me too.
Hadn't used the addon for a while as it didn't work with Comcast on Android but its working perfectly for me now. Thanks very much.
Beer money Donated THANKS Erack
Update 2016.10.21 Released
- Added Summit Broadband to the available providers
