Full Version: NBC Sports Live Extra
(2016-10-20, 21:56)eracknaphobia Wrote: [ -> ]Update 2016.10.20 Released
- Attempt to fix no audio in streams (legacy streams are used if available)
- Added Playstation Vue to the providers list
Thank you so much!! This works perfectly!
(2016-10-21, 19:25)eracknaphobia Wrote: [ -> ]Update 2016.10.21 Released
- Added Summit Broadband to the available providers
Works an absolute treat thank you so much Erack!!
(2016-10-21, 12:54)bluenose79 Wrote: [ -> ]I'm on latest version 2016.10.20 using Comcast/Infinity and everything works fine. Tested all live blue links, replays, everything is working 100% in glorious 1080p. Thank you so much Smile
Did you modify the global.py? Tried this on a pi3 running openelec and osmc. Still getting the same error message.
[/quote]
No I didn't touch anything, just updated to latest version.
double post sorry
Erack, is it possible to make a link for the main NBCSN channel, that would be fantastic for all.
(2016-10-22, 14:29)Atron Wrote: [ -> ]Erack, is it possible to make a link for the main NBCSN channel, that would be fantastic for all.
Not sure what you mean?
Erack thanks buddy, working great again. Just bought you a couple of beers for all your hard work. Hope you enjoy them, cheers ☺
Eracknaphobia.
Some of the links in Live and Up and coming today are not blue, is this purely the audio problem as discussed earlier in the thread ?
Eracknaphobia.
All Epl links now are blue, earlier 2 or 3 links were not blue.
The early game Bournemouth vs Tottenham did not turn blue at all.
Sorry to waste your time.
great work on the addon.
(2016-10-22, 15:51)kendof Wrote: [ -> ]Eracknaphobia.
go to the featured section, all blue link there instead
I looked at my error log, it seems the add on is using my email and password. But I don't pay for NBCsn, I'm using my friends login and password and that's not registering on the app (even though I entered it in the app settings). Anyway around this?
(2016-10-22, 16:42)Stadelta Wrote: [ -> ]I looked at my error log, it seems the add on is using my email and password. But I don't pay for NBCsn, I'm using my friends login and password and that's not registering on the app (even though I entered it in the app settings). Anyway around this?
Try switching the provider to one you don't use and pick a stream. This should reset some cookies. Then switch back to the correct provider and try a stream. If that doesn't work, delete the cookie.lwp file in the kodi\userdata\addon_data\plugin.video.nbcsnliveextra.
Getting an error when trying to access Live & upcoming:
11:10:11 T:7812   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <class 'urllib2.HTTPError'>
                                            Error Contents: HTTP Error 404: Not Found
                                              File "C:\Users\Paul\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra\nbcsn.py", line 487, in <module>
                                                SCRAPE_VIDEOS(url,scrape_type)
                                              File "C:\Users\Paul\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra\nbcsn.py", line 68, in SCRAPE_VIDEOS
                                                response = urllib2.urlopen(req)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 127, in urlopen
                                                return _opener.open(url, data, timeout)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 410, in open
                                                response = meth(req, response)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 523, in http_response
                                                'http', request, response, code, msg, hdrs)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 448, in error
                                                return self._call_chain(*args)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 382, in _call_chain
                                                result = func(*args)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 531, in http_error_default
                                                raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
                                            HTTPError: HTTP Error 404: Not Found
Kodi 16.1 (fresh install) Windows 10 x64 Pro.
Add-On version: 2016-10-21
NBCSports subscription through Comcast(Xfinity)
