Full Version: NBC Sports Live Extra
(2016-10-21, 05:52)Stadelta Wrote: [ -> ]Thanks for all the hard work, Erack. Happy to buy you a few lagers, but Comcast xfinity login still isn't working with the latest release 10.20.16 (at least for me). This was a fresh install.
"Please verify that your username and password are correct"
I get the same message as well.
(2016-10-22, 17:12)pTeronaut Wrote: [ -> ]Getting an error when trying to access Live & upcoming:
11:10:11 T:7812   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <class 'urllib2.HTTPError'>
                                            Error Contents: HTTP Error 404: Not Found
                                              File "C:\Users\Paul\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra\nbcsn.py", line 487, in <module>
                                                SCRAPE_VIDEOS(url,scrape_type)
                                              File "C:\Users\Paul\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra\nbcsn.py", line 68, in SCRAPE_VIDEOS
                                                response = urllib2.urlopen(req)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 127, in urlopen
                                                return _opener.open(url, data, timeout)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 410, in open
                                                response = meth(req, response)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 523, in http_response
                                                'http', request, response, code, msg, hdrs)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 448, in error
                                                return self._call_chain(*args)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 382, in _call_chain
                                                result = func(*args)
                                              File "C:\Program Files (x86)\Kodi\system\python\Lib\urllib2.py", line 531, in http_error_default
                                                raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
                                            HTTPError: HTTP Error 404: Not Found
Kodi 16.1 (fresh install) Windows 10 x64 Pro.
Add-On version: 2016-10-21
NBCSports subscription through Comcast(Xfinity)
Can you get to this link in your browser?
http://stream.nbcsports.com/data/mobile/...1-ios.json
(2016-10-22, 17:24)milli Wrote: [ -> ]
If possible try using a vpn that puts you on the East Coast of the USA and re-try.
(2016-10-22, 17:31)eracknaphobia Wrote: [ -> ]Can you get to this link in your browser?
Yes.
For those of you getting the "incorrect username or password" error with Comcast, login once through nbcsports.com on your device and play a stream, then try again with Kodi. It should work then.
(2016-10-22, 17:35)pTeronaut Wrote: [ -> ]
Yes.
Then there should be no reason why the addon can't get there. Does the Featured and replay sections work for you?
(2016-10-22, 17:52)eracknaphobia Wrote: [ -> ]
Yes.
No.
Edited add:
Seeing new errors in the log now.
11:58:10 T:6224   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.NameError'>
                                            Error Contents: name 'LIVE_AND_UPCOMING' is not defined
                                              File "C:\Users\Paul\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra\nbcsn.py", line 481, in <module>
                                                LIVE_AND_UPCOMING()
                                            NameError: name 'LIVE_AND_UPCOMING' is not defined
11:58:10 T:14964   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.nbcsnliveextra/?icon_image=C%3a%5cUsers%5cPaul%5cAppData%5cRoaming%5cKodi%5caddons%5cplugin.video.nbcsnliveextra%2ficon.png&mode=1&name=Live%20%26%20Upcoming&scrape_type=None&url=%2flive
11:58:10 T:14964   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra/?icon_image=C%3a%5cUsers%5cPaul%5cAppData%5cRoaming%5cKodi%5caddons%5cplugin.video.nbcsnliveextra%2ficon.png&mode=1&name=Live%20%26%20Upcoming&scrape_type=None&url=%2flive) failed
11:58:12 T:10080   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Contents: name 'FEATURED' is not defined
                                              File "C:\Users\Paul\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra\nbcsn.py", line 483, in <module>
                                                FEATURED(url)
                                            NameError: name 'FEATURED' is not defined
11:58:12 T:14964   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.nbcsnliveextra/?icon_image=C%3a%5cUsers%5cPaul%5cAppData%5cRoaming%5cKodi%5caddons%5cplugin.video.nbcsnliveextra%2ficon.png&mode=2&name=Featured&scrape_type=None&url=http%3a%2f%2fstream.nbcsports.com%2fdata%2fmobile%2fmcms%2fprod%2fnbc-featured.json
11:58:12 T:14964   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra/?icon_image=C%3a%5cUsers%5cPaul%5cAppData%5cRoaming%5cKodi%5caddons%5cplugin.video.nbcsnliveextra%2ficon.png&mode=2&name=Featured&scrape_type=None&url=http%3a%2f%2fstream.nbcsports.com%2fdata%2fmobile%2fmcms%2fprod%2fnbc-featured.json) failed
12:02:32 T:10056   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                FEATURED(url)
12:02:32 T:14964   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.nbcsnliveextra/?icon_image=C%3a%5cUsers%5cPaul%5cAppData%5cRoaming%5cKodi%5caddons%5cplugin.video.nbcsnliveextra%2ficon.png&mode=2&name=Featured&scrape_type=None&url=http%3a%2f%2fstream.nbcsports.com%2fdata%2fmobile%2fmcms%2fprod%2fnbc-featured.json
12:02:32 T:14964   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra/?icon_image=C%3a%5cUsers%5cPaul%5cAppData%5cRoaming%5cKodi%5caddons%5cplugin.video.nbcsnliveextra%2ficon.png&mode=2&name=Featured&scrape_type=None&url=http%3a%2f%2fstream.nbcsports.com%2fdata%2fmobile%2fmcms%2fprod%2fnbc-featured.json) failed
(2016-10-22, 17:57)pTeronaut Wrote: [ -> ]
(2016-10-22, 17:35)pTeronaut Wrote: [ -> ]Yes.
No.
NBC Sports Live Extra is accessible by my network, as I'm currently using Firefox to access it.
Try disabling any proxies you may have set. If you can get to the site through the browser but not kodi it must be something device specific.
(2016-10-22, 17:36)straightflushin Wrote: [ -> ]For those of you getting the "incorrect username or password" error with Comcast, login once through nbcsports.com on your device and play a stream, then try again with Kodi. It should work then.
It still doesn't work. It works on the browser but not in the addon.
(2016-10-22, 18:00)eracknaphobia Wrote: [ -> ]
(2016-10-22, 17:52)eracknaphobia Wrote: [ -> ]Then there should be no reason why the addon can't get there. Does the Featured and replay sections work for you?
No.
No proxies, both PCs have this issue (am troubleshooting this on a fresh install on my laptop, as the main Kodi install is on my HTPC using the TV as the display)
This issue is also present on Kodi on Android (Stock Sony 5.1.1), connecting via my network or by mobile data. (NBCSports Live Extra App working)
Edit to add error from Android (which appears to be the same as the 1st PC error)
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.nbcsnliveextra/nbcsn.py", line 466, in <module>
                                                LIVE_AND_UPCOMING()
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.nbcsnliveextra/nbcsn.py", line 35, in LIVE_AND_UPCOMING
                                                SCRAPE_VIDEOS(ROOT_URL+'mcms/prod/nbc-live-ios.json')
                                              File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.nbcsnliveextra/nbcsn.py", line 72, in SCRAPE_VIDEOS
                                              File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 126, in urlopen
                                              File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 397, in open
                                              File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 510, in http_response
                                              File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 435, in error
                                              File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 369, in _call_chain
                                              File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/urllib2.py", line 518, in http_error_default
12:26:51 T:18446744072423555072   ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.nbcsnliveextra/?icon_image=%2fstorage%2femulated%2f0%2fAndroid%2fdata%2forg.xbmc.kodi%2ffiles%2f.kodi%2faddons%2fplugin.video.nbcsnliveextra%2ficon.png&mode=1&name=Live%20%26%20Upcoming&scrape_type=None&url=%2flive
12:26:51 T:18446744072423555072   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra/?icon_image=%2fstorage%2femulated%2f0%2fAndroid%2fdata%2forg.xbmc.kodi%2ffiles%2f.kodi%2faddons%2fplugin.video.nbcsnliveextra%2ficon.png&mode=1&name=Live%20%26%20Upcoming&scrape_type=None&url=%2flive) failed
Mines off on kodi in android.Worked this morning but it had 5 sections instead of 3.Its went back to 3 and an error comes up "check the log"
For me this is crazy. I delete any hint of Eracks addon from Kodi using FileZilla. Reinstall. Use my friends xfinity login and password and for some reason it still retains my non functional xfinity email and password (that I don't have access to nbcsn. That's why I'm sharing my friends login and pwd!).
Any help would be appreciated.
If anyone is getting a "check your username and password" error try the following.
I was getting the error this morning when I knew my credentials were correct, I went to the NBC Sports app for my device (in this case Windows 10) and had to go through the device activation screens again.
After doing this the Kodi addon worked flawlessly Smile
So in short if you're getting login errors and your device has an NBC Sports app available try using that to activate your device then try using this great addon.
It looks like you can't use another person login and pwd if you are a Comcast customer. It automatically logs you in with your xfinity email and pwd that is associated with your IP address. Sigh.
Cheers erack, works with Comcast again! Was able to watch all the matches today. Smile
