Full Version: NBC Sports Live Extra
if i choose 8801 kbps quality i get buffering and freezing if i choose 5172 kbps quality then it is all fine....is there a server problem to streaming highest quality from nbcsports.com servers? any solutions?
hey at least you can log on Smile
Hey i really appreciate the work you done with add NBC sports extra but i log in with comcast account but it keep giving message that my username and password is invalid. i have that issues till the update. Could you help out mate
hi, erack, is possible to add in addon settings that allways use 5172 kbps stream quality? now we have option prefer best quality or manualy to choose....prefer best stream quality is ok but that settings have buffering....
Working like a dream for me , many thanks for getting this fixed and back up ,
I have started working on a beta version of this addon that employs the activation code login method. This method creates a code which you then take to a browser to activate your device. If this method proves usable, it should unlock all providers and be much easier to upkeep.
For any brave souls who wish to try the beta version the zip file can be found here. I've also added a link to the beta on the first post as well.
https://github.com/eracknaphobia/plugin.video.nbcsnliveextra-beta/archive/master.zip
I'd like to thank the guys who worked on the ESPN 3 addon for the inspiration.
Hi erack,
Just installed beta, went through activation and it works! I can watch a blue channel! Hope it continues to work, but thanks again for your great work on this app!
i tested this new beta and like it but i found a bug....there are just SD streams now? in addons settings i have prefer best strea quality but no 1080 HD streams?
(2016-11-18, 09:37)Bayern Wrote: [ -> ]i tested this new beta and like it but i found a bug....there are just SD streams now? in addons settings i have prefer best strea quality but no 1080 HD streams?
Ah yes, I reversed the order of the quality list. So now it's always picking the lowest instead of the highest. I will get this fixed shortly.
sweet!!!!
just installed the beta version
working again. just in time for the weekend!!!! :-D
Update 2016.11.18 Beta
- Fixed Play best option
- Added a deauthorize device option in settings
The beta can now be found in my repo as well for ease of access and automatic updates
that was fast but now addon not working for me using kodi 17 beta5.....also not working in kodi 16.1....here is log....
16:48:27.541 T:12552   ERROR: EXCEPTION: Unknown addon id 'plugin.video.nbcsnliveextra'.
16:48:27.542 T:12552   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.RuntimeError'>
                                            Error Contents: Unknown addon id 'plugin.video.nbcsnliveextra'.
                                              File "C:\Users\Vinko\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra-beta\nbcsn.py", line 1, in <module>
                                                from resources.globals import *
                                              File "C:\Users\Vinko\AppData\Roaming\Kodi\addons\plugin.video.nbcsnliveextra-beta\resources\globals.py", line 327, in <module>
                                                ROOTDIR = xbmcaddon.Addon(id='plugin.video.nbcsnliveextra').getAddonInfo('path')
                                            RuntimeError: Unknown addon id 'plugin.video.nbcsnliveextra'.
16:48:27.562 T:23220   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.nbcsnliveextra-beta/
16:48:27.562 T:23220   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra-beta/) failed
16:48:39.068 T:23220   ERROR: Control 55 in window 10025 has been asked to focus, but it can't
16:48:39.306 T:5868   ERROR: C:\Users\Vinko\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py:643: SyntaxWarning: import * only allowed at module level
                                              def logout(display_msg=None):
16:48:48.061 T:23220   ERROR: Control 50 in window 10025 has been asked to focus, but it can't
16:48:48.256 T:9284   ERROR: C:\Users\Vinko\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py:643: SyntaxWarning: import * only allowed at module level
16:49:02.532 T:7776   ERROR: Previous line repeats 2 times.
16:49:02.532 T:7776   ERROR: Unable to find plugin
16:49:02.532 T:23220   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://
16:49:02.532 T:23220   ERROR: CGUIMediaWindow::GetDirectory(plugin://) failed
16:49:47.604 T:20740   ERROR: EXCEPTION: Unknown addon id 'plugin.video.nbcsnliveextra'.
16:49:47.605 T:20740   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
16:49:47.612 T:23220   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.nbcsnliveextra-beta/
16:49:47.612 T:23220   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nbcsnliveextra-beta/) failed
16:49:59.767 T:23220  NOTICE: Storing total System Uptime
16:49:59.767 T:23220  NOTICE: Saving settings
16:49:59.772 T:23220  NOTICE: Saving skin settings
16:49:59.774 T:23220  NOTICE: stop all
16:49:59.774 T:23220  NOTICE: stop player
Ok, found some issues with path variables. Bumped fixed version to 2016.11.18.2
Erack, new beta works perfect, and high quality stream. Thansk for the effort!
Comcast login works again on the beta! Thank you for your diligence Erack!
