Full Version: NBC Sports Live Extra
Love the addon. Nice work!
A feature requests: any chance to have a folder with only the Premier League links? Or a filter option in settings to only show Premier League.
anyhow... thank you for the workBig Grin
(2016-12-28, 22:27)DxCor Wrote: [ -> ]Love the addon. Nice work!
Good idea, I'll see if I can make that happen.
Update 2016.12.29 Released
- Add a filter setting to allow users to customize the results shown in each section
- Removed No longer used httplib2 requirement
- Cleaned up some code
(2016-10-22, 17:24)milli Wrote: [ -> ]
(2016-10-21, 05:52)Stadelta Wrote: [ -> ]Thanks for all the hard work, Erack. Happy to buy you a few lagers, but Comcast xfinity login still isn't working with the latest release 10.20.16 (at least for me). This was a fresh install.
"Please verify that your username and password are correct"
I get the same message as well.
It works now(latest version) with the new authentication using activation code. Thanks eracknaphobia!
Working fantastic , add on seems to be getting better and better all the time Erack, thanks !
Just love the new filter option. Spot on. Thank you!
I cant get this addon work. Gives me error when i start it. Here is log: http://pastebin.com/0AFWGBfN
(2016-12-30, 18:16)DxCor Wrote: [ -> ]Just love the new filter option. Spot on. Thank you!
I have updated to the 29th version, how do you filter?
Im using krypton.
Regards
(2016-12-31, 15:29)fe33er Wrote: [ -> ]
Im using krypton.
Regards
New filter options in addon settings. Filter by sport and Category
When i download the repo on my mac it downloads as folder rather than a zip file, therefore i can't see to install from 'zip' within kodi, is there a way of doing this that is retard proof?!
(2016-12-31, 18:10)manutd77 Wrote: [ -> ]When i download the repo on my mac it downloads as folder rather than a zip file, therefore i can't see to install from 'zip' within kodi, is there a way of doing this that is retard proof?!
I've tested the link on a mac and it is a zip file. Here's the exact link it's going to which is indeed a zip file.
https://github.com/eracknaphobia/repo.eracknaphobia/raw/master/repository.eracknaphobia.zip
I'll be uploading the latest version to the kodi repo soon, so if you can't get the zip file you should be able to update from the kodi repo in a couple days.
(2016-12-31, 13:57)Jezze Wrote: [ -> ]I cant get this addon work. Gives me error when i start it. Here is log: http://pastebin.com/0AFWGBfN
Check your network settings. Some setting or service is interfering between the kodi device and the internet.
Here's the url it's having trouble loading:
http://stream.nbcsports.com/data/mobile/apps/NBCSports/configuration-ios.json
Had to authorize with the new app a again. Directv here. Watch the Lcfc game was perfect. No buffering just quality. Great stuff.
Just wanted to say thank you yet again for a fantastic add-on. It works really great
(2016-12-31, 19:16)eracknaphobia Wrote: [ -> ]
I made clean install for kodi. Now i get different error when i start addon. Here is log: http://pastebin.com/3keYYeyb
Edit: i updated my NIC drivers and now it seems working.
