When I download the Repo from the first page, (it says 10-02-18) and install it NBC sports is not in it ?
(2018-02-14, 11:25)Atron Wrote: [ -> ]When I download the Repo from the first page, (it says 10-02-18) and install it NBC sports is not in it ?
It's showing 2018.2.13 for me. You can open the context menu and check for updates on my repo. Or you could just download the zip manually from
github
(2018-02-14, 15:21)eracknaphobia Wrote: [ -> ] (2018-02-14, 02:56)moeSizlak Wrote: [ -> ]I'm now using 2018.2.13. Now, after de-authing and re-authing [successfully] (Verizon FIOS) I get a NoAuthz error when trying to play any blue video.
Post a log file.
The only thing that seems to be logged it:
20:49:20.257 T:3464 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.nbcsnliveextra/?url=http%3A%2F%2Fsprtlive24.akamaized.net%2Fhls%2Flive%2F586441%2Fnbc-olympics0213153303%2Fmaster.m3u8&mode=5&icon_image=http%3A%2F%2Fhdliveextra-pmd.edgesuite.net%2FHD%2Fimage_sports%2Fmobile%2F203548_m50.jpg&requestor_id=NBCOlympics]
Here is a link to complete logs if you want them:
https://pastebin.ca/3972785
(2018-02-14, 21:44)moeSizlak Wrote: [ -> ] (2018-02-14, 15:21)eracknaphobia Wrote: [ -> ] (2018-02-14, 02:56)moeSizlak Wrote: [ -> ]I'm now using 2018.2.13. Now, after de-authing and re-authing [successfully] (Verizon FIOS) I get a NoAuthz error when trying to play any blue video.
Post a log file.
Here is a link to complete logs if you want them: https://pastebin.ca/3972785
Authz error means you don't have access to the selected "channel" through your tv provider.
(2018-02-15, 21:41)eracknaphobia Wrote: [ -> ] (2018-02-14, 21:44)moeSizlak Wrote: [ -> ] (2018-02-14, 15:21)eracknaphobia Wrote: [ -> ] Post a log file.
Well I do have access to it. I can view all the videos in the NBC Sports app, and on all the PC's in my house, just not in your kodi addon. As I stated, I have Verizon FIOS TV. When I go authorize my device using the code displayed in the addon, I am directed to Verizon, and the processes is successful. The videos just don't play. Clearly there is a problem with the addon.
(2018-02-15, 23:24)moeSizlak Wrote: [ -> ]Well I do have access to it. I can view all the videos in the NBC Sports app, and on all the PC's in my house, just not in your kodi addon. As I stated, I have Verizon FIOS TV. When I go authorize my device using the code displayed in the addon, I am directed to Verizon, and the processes is successful. The videos just don't play. Clearly there is a problem with the addon.
Chill dude, I'm just letting you know what the error means. You stated you had verizon fios, which sounds like just internet. Now you say you have verizon fios tv, that's fine, I still have no idea what tv channels you subscribe to. Anyway it seems to be working for most everyone else at the moment, so I'm not sure what your issue is.
(2018-02-13, 23:15)eracknaphobia Wrote: [ -> ]Update 2018.2.13 Released
This now works for me - I was able to watch immediately after upgrading to this version (apparently the previous version had properly authenticated even though it didn't realize it). I also confirmed that de-authenticating followed by re-authenticating works. Thanks for the speedy bug fix!
(2018-02-15, 23:38)eracknaphobia Wrote: [ -> ] (2018-02-15, 23:24)moeSizlak Wrote: [ -> ]Well I do have access to it. I can view all the videos in the NBC Sports app, and on all the PC's in my house, just not in your kodi addon. As I stated, I have Verizon FIOS TV. When I go authorize my device using the code displayed in the addon, I am directed to Verizon, and the processes is successful. The videos just don't play. Clearly there is a problem with the addon.
I used a friend's login for a different cable provider and it worked. I contacted Verizon who said the problem is in the app. They directed me to
http://stream.nbcsports.com/nbcsn/ where I was able to login with my cable provider (Verizon) and watch all of the streams without any problem, so I do believe the problem is in how the app is attempting to authenticate. I watched the auth process using fiddler in both the app, and via
http://stream.nbcsports.com/nbcsn/, and while they both use AdobePass, they seem to be using a different API.
Hello, can someone please help. I’m trying to install the repo on an Apple TV. As it does not have a facility to download zip files, I installed the github repo via Indigo on TV addons repo. However, when I install it from there, the repo does not show up as having been installed although it says it is installed. Any help on how I can install the repo on an Apple TV will be appreciated
Chambai
Indigo and TV Addons are banned from this forum. While you are trying to use those add-ons, there will be no support for you here.
All working fantastic again here, thanks Erack
Thank you erack this add-on is by far my favourite,is there a possibility the NBC sports gold app could be ported too?
Can you watch the NBC gold live games on Saturday's Gazrob ?
