(2018-10-01, 22:32)Nicolm19781 Wrote: [ -> ](Authorisation failed) Invalid mvpd/requestor combination
I started to get this over the weekend too not sure if it's a an NBC thing or not but rolling back both nbcsnliveextra and script.module.adobepass to a previous version and everything worked fine
Update 2018.9.29 Released
- Fix activation issues (requires adobepass to be updated to 2018.9.29 as well)
Hello,
I got this to work after several attempts with activation codes, but since this update I now get error and it does not allow me the option to auth my device like it did before. Running latest Adobe Pass as well. The update has not worked for on Kodi 18 Beta 4.
I am having issues playing any NBC Sports events.It goes ass if its going to load and then stops.
Need help to watch the NBA Pre-Season Games
xml:
17:58:58.820 T:21368 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5
17:58:58.834 T:21368 NOTICE: VideoPlayer: Opening: http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5
17:58:58.834 T:21368 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:59:00.257 T:21368 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5
17:59:00.257 T:7456 NOTICE: Creating InputStream
17:59:01.062 T:7456 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
17:59:01.062 T:7456 ERROR: CCurlFile::Open failed with code 403 for http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5
17:59:01.062 T:7456 NOTICE: Creating Demuxer
17:59:01.908 T:7456 ERROR: CVideoPlayer::OpenDemuxStream - Error creating demuxer
17:59:01.908 T:7456 NOTICE: CVideoPlayer::OnExit()
17:59:01.921 T:21368 ERROR: Playlist Player: skipping unplayable item: 0, path [http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5]
17:59:01.937 T:21368 NOTICE: CVideoPlayer::CloseFile()
17:59:01.937 T:21368 NOTICE: VideoPlayer: waiting for threads to exit
17:59:01.937 T:21368 NOTICE: VideoPlayer: finished waiting
17:59:01.938 T:21368 NOTICE: VideoPlayer: finished waiting
xml:
17:58:58.820 T:21368 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5 17:58:58.834 T:21368 NOTICE: VideoPlayer: Opening: http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5 17:58:58.834 T:21368 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED 17:59:00.257 T:21368 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5 17:59:00.257 T:7456 NOTICE: Creating InputStream 17:59:01.062 T:7456 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403 17:59:01.062 T:7456 ERROR: CCurlFile::Open failed with code 403 for http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5 17:59:01.062 T:7456 NOTICE: Creating Demuxer 17:59:01.908 T:7456 ERROR: CVideoPlayer::OpenDemuxStream - Error creating demuxer 17:59:01.908 T:7456 NOTICE: CVideoPlayer::OnExit() 17:59:01.921 T:21368 ERROR: Playlist Player: skipping unplayable item: 0, path [http://sprtlive4.akamaized.net/hls/live/...0985b8e8a5] 17:59:01.937 T:21368 NOTICE: CVideoPlayer::CloseFile() 17:59:01.937 T:21368 NOTICE: VideoPlayer: waiting for threads to exit 17:59:01.937 T:21368 NOTICE: VideoPlayer: finished waiting 17:59:01.937 T:21368 NOTICE: CVideoPlayer::CloseFile() 17:59:01.937 T:21368 NOTICE: VideoPlayer: waiting for threads to exit 17:59:01.938 T:21368 NOTICE: VideoPlayer: finished waiting
Version of adobe pass I have loaded is showing 10.8.18. How do you get the 9.29.18 version? Add on no longer working for me after update.
I used this version of the plugin from erack's repo and it still works.
http://github.com/eracknaphobia/plugin.v...fe451f.zip
I also had to back adobepass down to the 3.20.17 version.
This is all referenced on a previous post (#3576). I have auto updates on kodi and when they were done for this add on in the last few days, it no longer worked.
I'm now unable to get it to work using either the new repos or the fix discussed above.
I had been running NBCSports 2018.2.13 and adobepass 2017.3.20 (auto-update turned off). That combination stopped working for me in the past few days. Freshly installing both of them does not work (gives 403 error when playing streams), though it does authorize correctly with my cable provider.
I've also tried to download the latest NBCSports and adobepass repos from the github directly, here and here,
https://github.com/eracknaphobia/plugin....nliveextra
https://github.com/eracknaphobia/script.....adobepass
but with this combination the activation codes provided by Kodi don't work with my provider.
any ideas appreciated
Ok new update: the most recent version of adobepass in github is 10.2, so I went back in the commit history and got 9.29 from here:
https://github.com/eracknaphobia/script....401a7fd7fe
Now I am using NBCSports 9/29 and adobepass 9/29 as erack instructed. The authorization codes now work again but I get this error:
"Invalid mvpd/requestor combination"
Also, for some reason, streams from local NBC affiliates have always worked in this add-on. Now, I get an "not part of your cable package" error for local nbc network streams. The error above is for national nbc sports programs.
Add-On no longer working for me now. Anyone have a combo of version of add-on and adobe pass that does work?
Sorry, there's no combo that works right now. Will have to wait on erack
NBCSports 2018.08.15 and adobepass 2018.10.08 are working for me at the moment and did authenticate with service provider on activation page.
I will mention that the Replays are not working for me though.
Thanks for the response. Not working for me unfortunately. Hopefully Erack will come through like usual...
Premier league match of the day link (further down the list of live and upcoming) is working. I think that one might show a game at each time slot
