Full Version: NBC Sports Live Extra
Looks like this add on has been abandoned
(2019-03-08, 04:19)NxtGenCowboy Wrote: [ -> ]Looks like this add on has been abandoned
I'd say that is an accurate assessment. Too bad. It was great when it worked. Undecided
Sorry I haven't been as active on the updates as I'd like to be, it's been a busy past few months. Looks like all streams use DRM now. Should be fixable, will update once I find out a solution.
NBCSN works though.
Only NBCGold doesn't.
Fantastic news Erack missed the app.
2019.3.15 Released to my repo
For now Inputstream Adaptive must be enabled for playback to work. So you'll need at least kodi 17 but I would strongly recommend using kodi 18 as that's what I've been testing on. I'm still working on getting playback without inputstream enabled. Will update once some headway has been made.
I don't think I'll be adding NBC Sports Gold into the mix as it's a completely different authentication that I really don't want to get into at the moment.
(2019-03-15, 18:08)eracknaphobia Wrote: [ -> ]2019.3.15 Released to my repo
I'm stuck with Kodi 17 as there is no stable version of Kodi 18 for the RPi, which is what I use. I'll give it a try with 17 when I have time.
(2019-03-16, 03:56)mrsfixit Wrote: [ -> ]
Nope, didn't work for me... Undecided
New version doesn't work for me either unfortunately on Kodi 18.1, error when starting playback. Log says "Error Contents: [Errno 2] No such file or directory: 'blahblah\\Kodi\\userdata\\addon_data\\plugin.video.nbcsnliveextra\\cookies.lwp'
I tried this version on LibreElec 8 (Kodi17.6) and CoreElec 9.0.1 (Kodi18.1) All items are working but NBC Sports Network channel.
On older version, NBC Sports Network channels and Olympic channels are working while others not.
not working for me either on 18.1
Working for me with raspberry pi and LibreElec 9.0.  Thanks Erack!
(2019-03-16, 16:35)mrsfixit Wrote: [ -> ]
Try using LibreElec 9.0.  It's Kodi 18 and has worked perfect for me with raspberry pi.
(2019-03-18, 03:13)rjhartman74 Wrote: [ -> ]
(2019-03-16, 03:56)mrsfixit Wrote: [ -> ]I'm stuck with Kodi 17 as there is no stable version of Kodi 18 for the RPi, which is what I use. I'll give it a try with 17 when I have time.
I will most certainly give that shot! Didn't realize LibreElec was up to version 9.0.
Thanks for the info! :-)
(2019-03-18, 04:13)mrsfixit Wrote: [ -> ]
(2019-03-16, 16:35)mrsfixit Wrote: [ -> ]Nope, didn't work for me... Undecided
Put LibreElec 9.0 on another SD card. It's working with the RPi.
Installed NBC Sports, but can't get the Live and Upcoming links except for the talk shows & the Olympics, to work. None of the Replay links work for me either. Can't watch a game of any kind.
Yes, I have a cable login. Watching a hockey game on my FireTV stick that refuses to load on the RPi.
Yes, I have InputStream enabled.
Is there some other setting I should have enabled to get this to work?
