(2019-03-20, 01:47)mrsfixit Wrote: [ -> ] (2019-03-18, 04:13)mrsfixit Wrote: [ -> ] (2019-03-18, 03:13)rjhartman74 Wrote: [ -> ]Try using LibreElec 9.0. It's Kodi 18 and has worked perfect for me with raspberry pi.
I will most certainly give that shot! Didn't realize LibreElec was up to version 9.0.
Thanks for the info! :-)
Put LibreElec 9.0 on another SD card. It's working with the RPi.
Installed NBC Sports, but can't get the Live and Upcoming links except for the talk shows & the Olympics, to work. None of the Replay links work for me either. Can't watch a game of any kind.
Yes, I have a cable login. Watching a hockey game on my FireTV stick that refuses to load on the RPi.
Yes, I have InputStream enabled.
Is there some other setting I should have enabled to get this to work?
In same section as InputStream Adaptive, do you have RTMP Input also enabled? I enabled this also and add on works. Not sure if that will fix your issue or not.
Also, LibreElec updated to 9.0.1 or something like that when Kodi updated to 18.1. May not have any affect on NBC Sports Add On though.
(2019-03-20, 02:41)rjhartman74 Wrote: [ -> ] (2019-03-20, 01:47)mrsfixit Wrote: [ -> ] (2019-03-18, 04:13)mrsfixit Wrote: [ -> ]I will most certainly give that shot! Didn't realize LibreElec was up to version 9.0.
Yes, RTMP is also enabled. Should have stated that before. And it is LibreElec 9.0.1.
I did the whole activation thing with my provider just like on the FireTV stick but just can't get any games of any kind except for Olympics.
Meanwhile, the Canadiens vs the Flyers played flawlessly on the FireTV stick, and wouldn't play at all on the RPi. When I clicked the link it just swirled for a few seconds and stopped. That's it.
Sigh... :-(
(2019-03-20, 04:24)mrsfixit Wrote: [ -> ] (2019-03-20, 02:41)rjhartman74 Wrote: [ -> ] (2019-03-20, 01:47)mrsfixit Wrote: [ -> ]Put LibreElec 9.0 on another SD card. It's working with the RPi.
Sigh... :-(
Sorry, I wish I knew more about the code behind these add ons. I will look at my settings again and see if there is anything else I can think of.
(2019-03-20, 15:36)rjhartman74 Wrote: [ -> ] (2019-03-20, 04:24)mrsfixit Wrote: [ -> ] (2019-03-20, 02:41)rjhartman74 Wrote: [ -> ]In same section as InputStream Adaptive, do you have RTMP Input also enabled? I enabled this also and add on works. Not sure if that will fix your issue or not.
Sigh... :-(
Thanks. Much obliged. :-)
Is anyone else not able to install the latest version? I'm stuck on version 2018.9.29. Kodi shows an update available and says that it is installed. It immediately gives me to notification that an update is available and stays on the previous version. I did a clean install on windows 10 using kodi 18.1. Only the eracknaphobia repo and nbs sports live extra installed. Any suggestions on how to get updated to the latest version?
(2019-03-30, 03:39)htownpensfan Wrote: [ -> ]Is anyone else not able to install the latest version? I'm stuck on version 2018.9.29. Kodi shows an update available and says that it is installed. It immediately gives me to notification that an update is available and stays on the previous version. I did a clean install on windows 10 using kodi 18.1. Only the eracknaphobia repo and nbs sports live extra installed. Any suggestions on how to get updated to the latest version?
I too am having the same issue!
(2019-03-30, 16:43)mrsfixit Wrote: [ -> ] (2019-03-30, 04:11)jfpark Wrote: [ -> ] (2019-03-30, 03:39)htownpensfan Wrote: [ -> ]Is anyone else not able to install the latest version? I'm stuck on version 2018.9.29. Kodi shows an update available and says that it is installed. It immediately gives me to notification that an update is available and stays on the previous version. I did a clean install on windows 10 using kodi 18.1. Only the eracknaphobia repo and nbs sports live extra installed. Any suggestions on how to get updated to the latest version?
Ditto for me...
Reinstalled Erack's repo, and NBC Sports, now it's working. Don't know what changed, but something did.
InputStream enabled, at default settings. The other one- RTMP, is also enabled and at default settings.
NBC Sports is set to automatically play the best stream. It activated, last night threw an error message that it had to reauthorize, then did so on it's own a few minutes later. It's working right now.
It still is on version 2018.9.29, and says update available, but it doesn't update.
Whatever. It's working, I can watch baseball, and all is right with the world for now. Fingers crossed it stays that way. lol
(2019-04-01, 23:32)komplex Wrote: [ -> ]The problem is that his github one is version="2019.3.15" but the one in the zip on his repo was version="2018.9.29"
Since it's working at the moment, I am leaving well enough alone, and unchecking auto update for that addon.
But it's good you figured out there were different versions. Never occurred to me... duh... lol
Actually version 2019.3.15 is in
my repo if you don't link directly to the previous version you would see that. A log file would let us know what is actually happening.
(2019-04-02, 01:02)eracknaphobia Wrote: [ -> ] (2019-04-01, 23:32)komplex Wrote: [ -> ]The problem is that his github one is version="2019.3.15" but the one in the zip on his repo was version="2018.9.29"
Actually version 2019.3.15 is in my repo if you don't link directly to the previous version you would see that. A log file would let us know what is actually happening.
Yes the one in your repo says 2019.3.15 but inside the zip the version number says 2018.9.29
Yep, that was exactly it.
Thanks @
komplex for pointing that out. Should be fixed now.
Thank you, works great for me now!
(2019-04-02, 01:20)eracknaphobia Wrote: [ -> ]Yep, that was exactly it. Thanks @komplex for pointing that out. Should be fixed now.
Any plans on working on NBC Gold links?
